Dec 19, 2022 at 2:11 PM Post #23,446 of 27,008
Is DAVE priced significantly lower in China than in the rest of the world?
I saw somewhere that brand new DAVE sold for $6k-7k last year. Is that even possible?
The current US MSRP of $14K is just too much Lol...
Dec 19, 2022 at 2:41 PM Post #23,447 of 27,008
You guys are paying about $3k extra in duty because you are importing a British product to the USA 😔
The same applies to us when we import products from the USA.
This is how tariffs damage trade.
Dec 19, 2022 at 2:44 PM Post #23,448 of 27,008
Looks like Classifieds is the way to go :relaxed:
Only 50% of MSRP :wink:
Dec 19, 2022 at 3:02 PM Post #23,449 of 27,008
That is true.
An advantage of the fact that Dave has never been updated is that the old models are as good as the brand new ones.
Dec 19, 2022 at 3:10 PM Post #23,450 of 27,008
No, the bass was not the reason (I know the nice deep bass you are talking about on that track, especially audible towards the end!)
41Hz, out of phase across the two channels. Seems like a serious recording mistake...
Dec 19, 2022 at 4:14 PM Post #23,451 of 27,008
In conclusion, it is clear that the Rossini Apex is a good DAC. It was just that I thought my Mscaler + Dave was better overall in several very clear ways and was the DAC which I would be happiest listening to long term.
After listening to your playlist with my headphones and amp, suffice to say I don't find them in the same league (I'll spare everyone my rants, feel free to check the Bartok thread), but a/b-ing is so tedious to me at this point , that I was very happy just listening using Dave instead. Sadly i'll never know what magical properties Sean Jacobs psus have to close the gap, but I'd point out that dCS uses more or less the same power solution from the Vivaldi down to the Lina. Same clocks as well. No magic there. And the manual actually recommends against using most of the audiophile cables pushed on the forums. How refreshing. People will do what they want ofc.
Your cost calculations are also pretty skewed, seemingly not taking into account that all you need is a (non-ferited) Ethernet cable to get music out of the Rossini. And it will sound as good as (insert number of) Taikos and Antipodes you might want to add in front of your chain.
Edit: To be fair, taking the clock out, does almost even the playing field so a point where I can almost see where you're coming from. The M-scaler still wouldn't put it above for me though.
Dec 19, 2022 at 5:12 PM Post #23,452 of 27,008
Well if it's out of phase that explains a lot, I've always felt the bass on "Thank You" sounded a little odd, that was the reason I mentioned it to Triode User. To be fair it's never really spoiled my enjoyment of the track, the only time it became an issue was when we used it as part of setting up my current speakers, but we all put it down to the new bass drivers needing to have a little time to free up, but at the time I did wonder whether we had the speakers in the optimum position, thankfully time has revealed that we did.
Dec 20, 2022 at 11:55 AM Post #23,454 of 27,008
Goes to show why I have always agreed with @Christer that listening to well recorded acoustic instruments, ideally from a performance in a venue you are familiar with is the best starting point when auditioning or comparing equipment.
Dec 20, 2022 at 1:21 PM Post #23,455 of 27,008
Not a clue about prices in China currently . But I was more than a a bit tempted to buy a new one just after it was released in Singapore for around 8500 USD. And even more tempted in Medan Indonesia a few years later at around 6500 USD new. But instead I setttled or a Qutest/Mscaler combo. Mscaler is imho the most important indgredient in the "Rob Watts cooking recipe", for me listening 99% to acoustic instruments music, recorded in a real acoustic space.
As you say the current MSRP both in the US and Europe are too much.
WAY TOO MUCH!!
Cheers Christer
Dec 20, 2022 at 4:45 PM Post #23,456 of 27,008
WAY TOO MUCH!!
Cheers Christer
Agreed!
Buying used from a reputable Head-Fi'er is the way :gs1000smile:
Dec 20, 2022 at 5:11 PM Post #23,457 of 27,008
@Rob Watts
I found a peculiar issue with the Dave recently. I just got my Envy in yesterday. Got everything hooked up etc. I started noticing a constant high pitched sound on higher volume levels. Much to high in normal listening sessions but it was still there and annoying me.
At first I thought the issue was with the Envy as I never noticed this issue on the Ferrum stack. Upon further inquiry, I noticed when I put the Dave in standby. The sound went away. Later I diagnosed it to be the LCD screen. When using Display 4 and the screen goes off the high pitched whine stops. Seems like the LCD screen is producing noise which the highly sensitive Envy is picking up.
Maybe the Ferrum did not have enough headroom to accentuate the issue. Or this might have been a new issue. Anyone noticed this before? Maybe with other tube amps? Thanks.
@Rob Watts Hi Rob, wondering if you aware of the LCD on the Dave adding some noise to the signal? In everyday use and volumes it is not heard but at higher gains its there. I noticed with the Feliks Envy.
Dec 21, 2022 at 1:40 AM Post #23,458 of 27,008
On measurements it's just possible to resolve it, but you are looking at something comparable to the FFT noise floor, so insignificant.
Nobody has ever reported hearing it though, and that's consistent with the measurements. This sounds like an issue solely with the Feliks - perhaps a grounding or RF issue. Perhaps the Feliks is picking up EMC multiplexing noise direct from the display via the air.
Dec 21, 2022 at 4:03 AM Post #23,460 of 27,008
Have you tried setting display to 4?
Does it help?
