CHORD ELECTRONICS DAVE
Oct 22, 2020 at 8:12 AM Post #16,006 of 25,909
As a follow up i just realized my old cable wouldn't even handle 24/96, i usually have Tidal set to play Hi-fi, not master and avoid mqa tracks, but i accidentally left in on Master today and a mqa track came up it just cut sound and Tidal switched outputs to my gaming soundcard.
Huh? But the stock optical and USB cables that come with DAVE and M-Scaler can handle 24/96.
Oct 22, 2020 at 8:19 AM Post #16,007 of 25,909
I can't test to compare ,since it's too short. The Sonorous one can as well, theoretically, if i play the windows sound options test tone through it at 24/96 it goes through, but if i Tidal Mqa track comes along it switches outputs.
Oct 22, 2020 at 8:53 AM Post #16,008 of 25,909
Oct 22, 2020 at 8:57 AM Post #16,009 of 25,909
Is it me or they screwed the manual up? https://chordelectronics.co.uk/wp-content/uploads/2016/09/Dave-User-manual.pdf
I followed the manual and I believe they miswrote the position of the left and right xlr connector. The Dave sounded really bad I was regretting my purchase 2 days into the Dave before I swapped my xlr cables connector around and got relieved!
Huh... You’re right. The manual is wrong. Didn’t even notice it because I just assumed the connector closest to the right speaker is the right XLR connector and same for left.
Oct 22, 2020 at 11:03 AM Post #16,010 of 25,909
Thanks for this, it is very much appreciated.
I take what Adrian says with a big grain of salt. I advise you to do the same :darthsmile:.
Oct 22, 2020 at 11:18 AM Post #16,011 of 25,909
I've just stated my personal opinions, just like with the m-scaler.
You can take this with a big grain of salt though, this cable made a bigger difference then the m-scaler (for the better) and i'm sure it's because the old optical cable was crap. It still sounded better than a 100 euro usb cable + jitterbug out of a macbook pro though so i'm not sure what's happening. I feel like i got a new dac though.
I can only conclude that's why the m-scaler sounded so bad and i'm getting it for another audition tomorrow.
Oct 22, 2020 at 11:53 AM Post #16,012 of 25,909
Good move!
I also felt the M Scaler made the sound brighter, but didn't equate it with «worse» – it was just brighter. It took me a few seconds to reduce the treble on my equalizer by a few µdB. Synergy is a dangerous thing (given that no audio component is really neutral, let alone sound transducers). It can fool you into thinking the less honest electronics component be the better one. Whereas to my ears the M Scaler is a revolutionary step towards high fidelity. It manages to make 44.1 kHz recordings sound better (more lifelike) than hi-res recordings, and hi-res recording still better than without it.
Oct 22, 2020 at 12:12 PM Post #16,013 of 25,909
Good move!
Well for me , with usb it was a lot brighter and with a noisy background, less definition, etc out of gaming pc. Better out of macbook, but still not as black a background as optical.
On optical though it was borderline unlistenable with the amount of smoothness added, it only later hit me that even solo Dave, though not as bright is a bit smoother on optical than usb, with a less clarity.
So much so that i could never go past CF2, since the image became too blurry, even at 2 sometimes.
With the new cable it's just as laser focused on CF3 as on CF0 and i honestly barely recognize my playlist. There's much more depth, the timbre is much improved and there's a sense of higher resolution.
I'm still shocked there's such a difference between optical cables when the popular opinion is "they all sound the same ". I don't know if Kabeldirekt or other "cheap" usb cables are closer to the QED or the dumpster fire of the Sonorous i was using, but it kinda makes me also want to try a better power cable.
I'm sure this will fix the weird veil on the m-scaler, but i'm still left with the brighter sound that i'm not sure how much the ferrites and lpsu's can compensate for.
With this new cable Dave sounds even darker though so maybe a bit of brightness wouldn't be the end of the world.
I guess i'll see tomorrow.
Oct 22, 2020 at 12:37 PM Post #16,014 of 25,909
Dont forget that you're not bound to your headphone's factory setting! (In case it's still too bright.)
Oct 22, 2020 at 12:49 PM Post #16,015 of 25,909
I agree, but now that i've heard this cable, i can't unhear it. And i'm kinda calling bs on Dave's jitter immunity. Bent or not, the old one never made DAVE sound like this.
So i'm more curious what effect would reducing jitter further would have, and i think the best way to do that is starting at the source. And it does resonate with what others have been saying about usb reclocking and etc.
I'm still skeptical but i have to hear it for myself.
IMHO the most important thing with optical connections to Dave is that they fit tightly and click into place. Dave's housing and recessed optical inputs prevent this with optical cables with large connectors. Did your original optical cable fit correctly? It should be hard to disconnect? Perhaps high signal attenuation is the issue not jitter. Rob Watts doesn't do bs. I had problems with a van den hul optocoupler optical cable. The optical fibre must have failed as it didn't work at all, even though it transmitted the red light.
Oct 22, 2020 at 12:50 PM Post #16,016 of 25,909
Well the Z1R is far from bright, but i guess i just prefer a darker sound signature. I haven't tried eq'ing my headphones yet, that's a whole other can of worms i'm not sure i'm ready to open.
Oct 22, 2020 at 12:52 PM Post #16,017 of 25,909
IMHO the most important thing with optical connections to Dave is that they fit tightly and click into place. Dave's housing and recessed optical inputs prevent this with optical cables with large connectors. Did your original optical cable fit correctly. It should be hard to disconnect? I don't think Rob Watts does bs. I had problems with a van den hul optocoupler optical cable. The optical fibre must have failed as it didn't work at all, even though it transmitted the red light. Perhaps high attentuation is the issue?
No the old one wouldn't click in Dave(thought it would go in deeper) or the m-scaler, it didn't even lock into the m-scaler, one nudge and it would fall off. It doesn't really click securely into anything , not like the new one.
Oct 22, 2020 at 12:56 PM Post #16,018 of 25,909
Has any one tried the Supra Optical cable? It is suppose to transmit high band width, guaranteed for 32 bit/384 kHz. Up to 20 metre cables are available. I'm not sure if the Supra connectors will fit the Dave though?
Oct 22, 2020 at 1:01 PM Post #16,019 of 25,909
That was the problem, attenuation and focus on the optical receiver, not jitter. I have no idea why Chord fit recessed optical connectors. I experienced this problem on a Chord QBD 76 DAC years ago.
Oct 22, 2020 at 1:19 PM Post #16,020 of 25,909
Yes the XLR connections shown in the Chord User Manual (photo in section 3.4, page 14) is incorrect. All Chord Choral products that have XLR balanced or RCA single connections have the red / right channel on the RHS of the unit as you look down at the unit with the units front facing towards you. I did the same thing when I first connected it up and it didn't sound good. So I guessed the manual was wrong and changed them over.....and then wow...great sound !
