Rob,
When I mentioned a passive preamp, I was thinking in terms of something simple to DIY, ie basically two variable potentiometers (one per channel), just two reduce the 2Qute output voltage.
The only problems I can envisage, are shielding the wires and components from RFI, but surely a simple small metal case would be sufficient.
Maybe passive preamp was the wrong term for me to use.
You have made me concerned, that even a simple solution like this, still contains hidden problems.
Hello
@miketlse. Yes, the term "pre-amp" I used is technically wrong, since the signal is not pre-amplified in any way, I think a more proper term would be "volume attenuator": a device that takes the output voltage from 2Qute DAC, and without any electronic power, attenuates it. I was researching yesterday about this. Here is one I really like it:
http://www.tisburyaudio.co.uk/mini-passive-preamplifier
Those Volume Attenuators are wrongly called "preamp" I think (signal is not amplified/pre-amplified in any way). So this Volume Attenuator responsibility would be to take the 3V ouput of 2Qute, and reduce it before reaches my powered monitors. Remember that all of this has one single objective: keep my music player (foobar2000 or others) at full volume, in order to be
bit perfect audio.
But
@Rob Watts says above that "you are creating problems by adding a passive volume control.", and I infer from him this:
1. 2Qute, due to its galvanic insolation, guarantees pristine audio with very low levels of noise, etc.
2. Any device dropped
after the DAC is outside 2Qute jurisdisction, then the DAC can do nothing about it before its signal reaches the powered studio monitors. Example: a Volume Attenuator (passive preamp) could somehow add RF, distortion etc and then directly trigger that into the speakers.
@Rob Watts, I swear you that I would have prefered to pay 60-100 USD more for the 2Qute, if it included a built-in volume attenuator: this has resulted extremelly important in my setup. (we shouldn't delegate volume control's reponsibility to any music player software, because then we would need to "trust" in the software volume control not degradding the bit depth.
At this very moment, I discovered something that somehow is helping me out with volume control with the 2Qute:
In foobar2000, go to: Preferences > Advanced > Playback: "Volume step (db)" option. If it is set to something like 0.3 or so, I have a very precise/delicated volume control by software....... but I am sure I am not having bit perfect audio. (I really do not like this approach, since what is the point of having a USD 1,795 DAC if you will end not having perfect bit audio?)
So I have two options right now: Keep using the "Volume step (db)" option in foobar2000, or add a passive volume attenuator
after the DAC and
before my powered speakers (at the high risk of degrading sound quality/adding noise, etc)
