supervisor
About to buy this one, just to clarify, so it still has no spotify connect and google cast? But since i have an iphone i can use airplay? Thanks in advance
there will be Spotify Connect soon
Gofigure ain't a music playing app, (or at least not in any sort of practical user friendly fashion unless you're extremely happy working solely with MPD playlists) - it just looks after Poly settings.
Ok so basically the only thing I want poly to do is play music from the SD card via dlna app with my phone as a remote. Is bubble the best option for Android.
I think that the best news in that 2Go announcement for us Poly users is that GoFigure will get far better than it is at the moment.
Works for me!
Works for me!
I think there was a similar post a week ago - the suggestion was along the lines of check the settings relating to 'connect to last network' or 'connect to strongest signal'.i just got this and everything seems fine but it seems after disconnecting it and using it again its a hit and miss whether It will find the poly again, its in the latest firmware and using an iphone 11 pro
For exampleHave you heard anything or just a guess?
Are you trying to connect via wifi or airplay/bluetooth?^i think its a different case... mine just sometimes will not find the poly from the gofigure app, its a hit and miss
