Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
958 959 960 961 962 963 964 965 966 967
969 970 971 972 973
  1. PrittiPoly
    Also, have you tried reindexing the SD card?
  2. Paulus XII
    I have a doubt. Hope you guys can help. When I connect to WiFi, can I listen to music via streaming from Android phone? Or do I have to use BT for this?
    The thing is that I hear no sound from WiFi connection inside Tidal, Spotify, whatever. Is this connection just for use with SD card? To work like a DAP?
  3. Paulus XII
    Figured it out! OMG, the sound quality via Wifi :O
    Using mconnect.
    EDIT: Is there anything better than mconnect that you would recommend for TIDAL? I'm not finding an option here to create playlists or add songs to favorites.
  4. miketlse
    Cantata is popular for creating playlists, but there are other apps often mentioned on this thread.
    Paulus XII likes this.
  5. Paulus XII
    Thanks mate, let me try that.
    EDIT: does not exist for Android...
  6. miketlse
    Versions for windows, Linux and Mac, so I create the playlists on my PC, and they are saved to the poly.
  7. jldevo
    I’ll try that. Thanks.
  8. DavidW
    I signed up with Qobuz the other day (having reduced their monthly fee was a real plus) and I will evaluate it over the first month during the trial. I set up my Poly using my Qobuz id and password and I can now play tracks from Qobuz.
    However... Qobuz displays a track hi-res tracks as 96k. When I tap on "ChordPlayer" (my local name) on the bottom left, I see my only choice is to play Qobuz on my iPhone or on the Poly via Airplay. The Mojo ball is red indicating 44.1k. What settings do I need to put in place to play Qobuz as a hi-res recording?
  9. vkvedam
    @DavidW Don't use the Qobuz app through Airplay. You need a third party app that can use Poly as a renderer. Other iOS users will chime in.
  10. muski
    Mconnect for iOS supports high-res Qobuz playback by using Poly as a renderer.
    Peter Hyatt and masterpfa like this.
  11. DavidW
    Thanks. Found it too, right there, on the Chord Poly FAQ page:
    HOW DO I CONNECT TO AND PLAYBACK TIDAL AND QOBUZ CONTENT USING GOFIGURE?​
  12. miketlse
    No need to shout.
    Today Gofigure is just an app to configure poly, and enable you to play playlists stored on the poly.
    To listen to Qobuz, you have to use a different app/software to stream the music to the poly.
    Options include mconnect, bubbleunp, roon, qobuz app, depending on whether you are using phone, tablet, laptop, plus windows/ios/android etc.
    There is a lot of info already posted in this thread, if you search using the term 'qobuz'.
  13. DavidW
    Sorry. I just copy and pasted the text from the Chord FAQ page.
    l have been learning more about Qobuz in the last few days. Appreciate the tips.
    Peter Hyatt and miketlse like this.
  14. melomania
  15. vkvedam
969 970 971 972 973
