ZappaMan
@Matt Bartlett i installed the latest firmware and Gofigure and Roon now works.
Is there another firmware released? My Roon is still broken. Jriver works though.@Matt Bartlett i installed the latest firmware and Gofigure and Roon now works.
V 2.0.3Is there another firmware released? My Roon is still broken. Jriver works though.
Hi @Matt Bartlett , just a quick question, do I have to power off poly before ejecting the SD card?
Thanks for the quick reply and the clarification. That is convenient.No in my experience it is not necessary. However good practise will advise on switching off before ejecting any memory device just in case it is being written to at the time. In this case if you are really unlucky you might cause corruption on the drive or card and you
could loose your data. With music on an SD card the risk is pretty small and even then you will usually have the music stored somewhere else so you can just format the card and start again.
I plug SD cards and USB memory sticks in and out of computers (and now Poly) all the time and I've never had an issue.
yea that's what I have... still brokenV 2.0.3
My Roon also not work with my poly with firmware 2.03yea that's what I have... still broken![]()
And did you also update Gofigure ?My Roon also not work with my poly with firmware 2.03
Yes ..... also updated to the latestAnd did you also update Gofigure ?
The only thing I can think of is, this upgrade was smooth and took 1 minute, the previous one, which was when it broke, took hours and I hadn’t a clue what I was doing.Yes ..... also updated to the latest
Yes I also updated GoFigure...And did you also update Gofigure ?
