Carabei
- Nov 29, 2007
At least for iOS is possible to be connected to Wi-Fi and use also mobile data, the solution has to be done on Poly side and it is that Poly gives iPhone only IP and Router but DNS is set to 8.8.8.8, so iPhone knows where to find Poly and rest is done by mobile data.
Solution for Android is not so easy as it doesn't allow this configuration, workaround is different, Wi-Fi direct is used here, so you don't miss your data.
I don't know if these solutions were implemented in Poly but at least exists and works, already used on one project.
