ZappaMan
I think they are one and the same! The one in the photos upthread. I just have issues with it.
sacre bleu
This is a report on my stupidity, but it might help others. In places where I can't get a wifi signal I have been connecting my android tablet to Poly in hotspot mode and using Bubble upnp. That's frustrating because for some reason Bubble cuts off the first half second of every track. When I have wifi I use M.A.L.P., which works brilliantly. I then thought I must be able to use M.A.L.P. when connected to poly in hotspot mode. Doh. All you need to do is create a profile in M.A.L.P. called Poly Hotspot which gives poly's IP address as 192.168.1.1, no password, default port number. Probably everyone else had worked this out ages ago.
And when the long awaited Android GoFigure is out, no doubt this will all be even easier...
MY M.A.L.P. PROFILES..
I had an interesting situation yesterday. I’m not sure if it was a true lockup, but my blue Poly light was stuck on and would not turn off when I cycled Mojo on/off or separated Mojo and Poly. But I was able to use GoFugure to connect, and change the mode to HotSpot, which triggered a Poly reboot and I got the flashing blue/green. A Mojo power cycle then turned off Poly. Working normally now. Something you can try if you get a similar “lock-up.”
Mines got Poly embossed on it as well. Makes all the difference mateYup, exactly the same albeit the word poly has not been stamped into the leather.
Hence why I was confused at zappamans post, he must of assumed that his case was special and that others were jealous.
< can easily engrave the word poly in to leather, plastic, back of my hand, forehead etc etc.
However, I do draw a line when it comes to defacing a £79 piece of plastic, would rather use brake fluid to polish my car and a piece of ceramic from a sparkplug to open my windows.
War ah huh, hooah, what is it good for, absolutely everything yeaaah.
That is the free case!Say what you want - I’m sure independent verification would confirm it’s much nicer than the free case - everything’s subjective!
