scook94
- Nov 26, 2013
Additionally you can use something like bubbleupnp or hifi cast as well to stream via dlna instead of playback using mpd. Both apps should work on any android phone. One of the issues right now with MPD is that for some reason the poly does not index mp3 files, so in order to play them back you have to browse to the files and add them to a playlist (i think everything with mpd is via playlists). DLNA indexes things fine, but will actually stream I think back and forth over the network. Its not necessarily a bad thing, but its 100% reliant on the connection to your phone, while MPD you can just set it to start playing and it should keep going even if you disconnect for some reason. The only other issue with DLNA is that on the poly its not gapless.
Hopefully they are working to make dlna gapless, add mp3 indexing, and hopefully the gofigure app will be out soon. I believe chord said it would release 6 weeks after the iOS version released, which if I am not mistaken would mean that this coming Sunday would be the release date. Given how long it was delayed on iOS I am not holding my breath, and it would actually shock me if it released when they said. Still hoping though, and at the very least am hoping it releases before I go on vacation towards the beginning of June.
You use the Mojo/Poly to play mp3s?
