I have a Samsung UE48JS9000.
With the FW 1.0.17, i have observed that if i have used the Poly with bluetooth audio, I need to turn off the TV before I can use the Poly with WIFI. The p.status was fix blue but it was impossible to use the Poly with BubbleUpnp and S8.
I did not report this because only me had the problem and i had found my solution.
With the FW 1.0.26
After my last post, the Poly blinking purple, i reconnect on the tv. The sound comes but on the display off the tv, i can find the Poly. When i try to refresh, the Poly is not finded by the TV and the sound is still there.
So the handshaking of the Poly and my TV must be improved.
The solution about blinking purple came when i turn off the TV.
About interruption in the sound, with my TV, the Samsung S8, S3 and the A10, i can not actually coreĺlate the frequence with events. With the TV, sometimes 3 interruptions in 10 secondes but generaly when the connection start. After one per minute or less.
I use the App Bluetooth LE scanner: it shows level RSSI. without succes. The levels change to quickly to understand something with these tools.
The last hour i have removed some bluetooth equipments in the list of the TV
and the number of interruption decrease a lot. Strange. I can now listen to my TV with pleasure in the night.
After i have done the same with my smartphone S3 but i have interruption like the first day: each 2 secondes. And with the S8 is near the same.
I repeat that i have connected 2 Poly with a smartphone Huawei in bluetooth audio and all is perfect.
My conclusion: Samsung has to work. I have request support for the smartphones and i wait.
Best regards
Jean
