Amberlamps
Formerly known as Phuca
- Jan 22, 2017
Quick question for those who have received replacement units - when you say that you're getting the Poly to start-up "right away", are we talking actually right away, or around 30 seconds?
I'm trying to figure if a couple of my quibbles might be with regards to my unit being from an older batch:
- Sometimes I cannot get Poly to "wake up" without plugging it into AC power (even when it's fully charged)
- Getting frequent wifi dropouts causing stuttering on SD-card playback using M.A.L.P on Android
- Roon over my home wifi stutters, speeds-up, distorts, and is generally un-usable.
Any pointers would be greatly appreciated!
I had my polly replaced, original one was PO206** I cant remeber last two numbers, when it was cold it took roughly 1-2 minutes to start, when it was warm it took 20-30 seconds.
My new Poly po26***, boots up within 20-30 seconds all the time.
If your poly does not turn on and only turns on when connected to a charger then you need to have it replaced with a newer upgraded poly.
The first few polys were set to turn on when detecting a certain voltage from mojo, Chord then made changes to poly so that it turns on if it detects any voltage from mojo. If I recall correctly.
