Matt Bartlett
Member of the Trade: Chord Electronics
This is very useful, I agree, and would appreciate @Matt Bartlett opinion here!
Hi! Mojo and Poly both feature charge control and monitoring circuits to make sure the internal battery is managed and charged correctly. My only advice really to get optimum performance is to make sure initially Mojo is switched off and given a full charge. Once fully charged then you can continue to play and charge at the same time. When you've finished playing then again switch Mojo off. Using this method ensures that the battery reaches full charge capacity and then the charge circuit will switch off.
Poly is different because it is much lower power. This means the charge circuit will always switch off even when Poly is on and left constantly on charge.
Also just to confirm when Mojo and Poly are connected together and on charge then you know both products are fully charged when the M status light is off (bottom) and the P status light (top) is blue, or flashing blue/green depending on which mode Poly is in ( network or hotspot ). Neither of them should be showing white indicating charging is still in progress.
Hope this helps.
