Lan647
How is the Poly working with Roon? That’s the only connection Method I care about. Do these problems everyone are having apply to the Roon integration as well?
Thanks.
Thanks.
You toggle your poly into roon mode versus a general mode.How is the Poly working with Roon? That’s the only connection Method I care about. Do these problems everyone are having apply to the Roon integration as well?
Thanks.
Try switching the Poly off and on again, force quit Glider and restart the app... should now work...
Can't speak for MPDeluxe as it never worked with my previous (first) Poly and I got refunded for the app, never re-purchased since I always stayed with Glider since.
Anyone else using ALAC files with MPDeluxe successfully?
Thanks.
In the absence of any update from Chord we are still supposed to believe that Apple are taking their time reviewing the app/hardware!!
More likely it had a timely rejection and the normal slow development pace has kicked back in whilst Chord try to fix the bugs. If the don't comment they think they won't be blamed for the delay and won't need to update us with the reality and who is actually making the app (available for iPhone & Android - as was stated in the manual on purchase November last year) delayed.
Well Apple either doesn’t like the app or Apple doesn’t like the hardware. Or both.
Hopefully it’s just the app, so Chord can work to meet the requirements to get it approved so Chord can deliver the functionality we were promised. Now we’re getting Bluetooth encrytion as a bonus? I suspect that was an Apple minimum requirement -and likely for a very good reason.
One thing that the App Store approval processs does is to ensure the end customer (us) isn’t subjected to half-baked apps with usability and security issues. They test UX, functionality, and security. It’s a bit ironic that the half-baked Poly’s central control app is apparently caught in that 3rd party quality assurance loop, isn’t it? More worrying that Chord have changed the design of the poly hardware during that process and are quietly swapping out units at a seemingly high rate without being clear on a serial number range recall.
I have a “Version 1” Poly with some of the same power issues described on here, and am waiting till the app officially launches to further test and then get it dealt with so I know I’m getting the final (Apple app approved) hardware version in my exchange, if I need to exchange it.
The Poly was 'upgraded' to detect the Mojo being switched from a specific voltage sensing to the presence of a voltage
I've had a search but there's a lot of material in this threadDoes anyone have a rough idea of serial number ranges for the Polys that might need a return for power issues?
Hi Keith,
Where are you located? I can put you in contact with a local dealer that stocks the cases.
Thanks
Thanks.
The Poly was 'upgraded' ...
Those of who decide to sell our Poly units to Mojo owners could get the new owners finding they don't seem to work, even those here not experiencing any issues could face this later unless they sell the Poly/Mojo together.
Were you an existing Mojo owner?
Could those of you who have said that Roon is working well for you please identify what WAP you are using for your network? I have an all Meraki network and I can't get more than a couple songs into an album before the Poly drops off the network and Roon stops playing. I know it is the Poly and not Roon, because I can see the Poly disconnect in my logs. I'm willing to add another brand of WAP to my network just for the Poly but I'd to know which one to get in the US market.
