NaiveSound
- Nov 8, 2015
I can't control sd card in any wayYes the app allows you to swap between modes.
There has been some discussion over at the Roon Labs community that Roon is working on Roon for mobile devices outside the home. That would make Roon a more universal solution for playback. The quality of playback is exceptional. Their big problem in the US is really that Tidal is their only Hi-Res streaming source. If you add the cost of Tidal HiFi and Roon it's just about the same as Qobuz Sublime+. That could be a problem for some.
you are 100% sure the network name and password is correct? maybe try restarting your iPhone or deleting the PH network and re-adding it.
i have zero issues connecting to iOS Personal Hotspot.
Well finally got eveeytheve going (1. 17), everything including sd card works, i really enjoy it now. Obviously when the GGoFigur app for Android gets released it will be ever better as we can switch modes wjthout the needle
And we will be able to control sd card with bluetooth
My only grump about it all is the uneven physical match between mojo and poly
I hate that it's bent, I suppose it's poly that is bent but it could be mojo I cant tell.
But it all works good.
Any ideas why/how music sounds better when streamed from Roon?
Replacement poly and latest firmware update : all working without fault with Glider beta!
This build of Glider has just been released to the App Store as the official 1.7.0 release. A big thank you to the community here for the incredible amount of help and feedback you continue to provide us with.
We've also been hard at work on the upcoming 1.8 feature set, which will add iTunes File Sharing capability so you can stream files stored on your phone to your Poly, including Hi-Res Flac and DSD. If anyone is interested in this feature, send me a message and I'll get you set up with an early TestFlight build.
