Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Feb 27, 2024 at 9:09 AM Post #18,571 of 19,930
I have mojo 2 and I bought more poly
Before using Poly, my Mojo 2 connected to my Laptop and worked great
However, after using it with Poly, the device's volume becomes very low
Even when I removed the poly and just used the Mojo 2 as before, the volume was still very low
Has anyone ever had this problem and how to fix it?
Make sure whatever app you are using to control Poly and feed music is set to “bit perfect” or full volume. Then use the Mojo volume buttons to control the volume. That will give you the best sound quality.
Feb 27, 2024 at 9:11 AM Post #18,572 of 19,930
Thanks for replying!
Is there any way to completely reset Mojo 2?
when i say software issue, i mean that the volume on your computer or in the application you're using might be low.
They say specifically that the volume remains low when not using the poly.
Feb 27, 2024 at 12:33 PM Post #18,573 of 19,930
My Macbook always resets Mojo2/Pily volume to minimum. Just add volume on your laptop.
Really? My Mac always sets it to maximum as the Mojo2 volume can't be controlled from the Mac. How weird!
Feb 27, 2024 at 1:35 PM Post #18,574 of 19,930
Are you using Poly?
Feb 27, 2024 at 1:54 PM Post #18,575 of 19,930
Are you using Poly?
Not until tomorrow when it arrives. USB connection. Does the volume control change if I Airplay to the Poly?
Feb 27, 2024 at 5:49 PM Post #18,576 of 19,930
Yes, with Poly my Macbook always uses volume control and I want to find out how to turn it off.
Feb 27, 2024 at 9:54 PM Post #18,578 of 19,930
Feb 28, 2024 at 4:28 AM Post #18,579 of 19,930
Ah I see. Of course it's treating the Poly as any other Airplay device. You could try writing a small Automation that checks if you're connected to the Poly and then sets the volume to 100%
Actually, scrub that. There isn't an 'Automations' option on Mac...only on the iPhone.
It would need an AppleScript and I've no idea how to do that
Feb 28, 2024 at 12:07 PM Post #18,580 of 19,930
There's a Mac app called Automator that might be able to do what you want.
Feb 28, 2024 at 12:24 PM Post #18,581 of 19,930
I did have a look at that but for the life of me can't figure it out. I made an Automator script in the past but can't recall how to do it now
Feb 28, 2024 at 7:34 PM Post #18,582 of 19,930
In System Settings, go to Sound. then click on Output. Your Poly will show up there. Set the Output volume all the way to the right. That should set the default volume to 100%.
Of course, AirPlay limits the res to 16/44. You would need to use different software and a network connection to get a higher res.
Feb 28, 2024 at 7:50 PM Post #18,583 of 19,930
Wow, I'll try that. Thanks!
Feb 29, 2024 at 12:32 PM Post #18,584 of 19,930
Tried that but sadly when you switch back to MacBook Pro Speakers, the volume stays at 100%. If you turn down the volume then switch back to Poly, the volume stays low. The description of BitPerfect in the GoFigure app doesn't do what it describes either. It should solve the issue but doesn't.
Feb 29, 2024 at 12:34 PM Post #18,585 of 19,930
A bit of help for a new Poly user please:
In order to Airplay to the Poly from a Mac, do I always need to select the Poly from the global Output Device setting or should I be able to select the Poly from the Music App instead?
When I use the Music app to select it, it does switch to the Poly but with a regular break-up of the audio every second or so. It doesn't act the way my other Airplay devices work.
What should I expect?
