Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Feb 22, 2024 at 5:27 AM Post #18,542 of 19,435
Feb 22, 2024 at 7:24 AM Post #18,544 of 19,435
Feb 22, 2024 at 7:50 AM Post #18,546 of 19,435
But why? What is this new server doing... apart from updates?
I was wondering the same thing. Not sure I would like a device that somehow required an internet server to function properly. Updates seem like the only logical use.
Feb 22, 2024 at 11:33 AM Post #18,547 of 19,435
I was assuming that Poly is already a server and this was an update to the server.
Optimistically I see a new server as something you can more easily update (with your permission to update) and stops the blockage people have been complaining about the current process.
Feb 23, 2024 at 5:48 AM Post #18,549 of 19,435
My question was referring to the type of connection between your phone and the Poly, do you let your phone act as a hotspot and connect the Poly to it or do you set the Poly to hotspot mode?
I use my phone (Pixel 8 Pro) as a hotspot and use the Go figure app to connect the Poly to the hotspot. I am then able to use Mconnect to access Qobuz/Tidal or my folders on my SD Card.
If I know I am going out I enable the hotspot on my phone before starting the Chord/Poly
Feb 23, 2024 at 6:03 AM Post #18,550 of 19,435
Anybody having trouble with the new firmware update? After updating to v3.2.4 BubbleUPnP (and other apps) aren't able to see my Poly anymore in WiFi mode. It's being recognized by GoFigure but that's about it, can only play music through bluetooth currently & hotspot mode.
Feb 23, 2024 at 6:55 AM Post #18,551 of 19,435
Try reindexing your SD card
Feb 23, 2024 at 10:15 AM Post #18,552 of 19,435
Nothing so far, though I've just been using it to stream Classic FM via the radio function
Feb 23, 2024 at 10:21 AM Post #18,553 of 19,435
by 'new server' i'm pretty sure they mean that the server address, which has been disignupdate.com, will be changed to another one.(or maybe it's not even that, but just a certificate update?) nothing that would impact you locally.
Feb 23, 2024 at 12:57 PM Post #18,554 of 19,435
Just got my Poly yesterday :)
Can it play files from FAT32 SD card or I need to re-format it to exFAT?
  • Back
