>Your use cases are incredibly specific.
I hear that more often, lol.
>Mojo was developed more for the mobile market, so bluetooth remotes wouldn't fit that bill.
fair enough
>>can files be added to the µSD via an ssh or other wireless connection?
>I would have liked to have seen that. As we have seen a few firmware updates, and because that isn't available on Chords 2Go, I think it's unlikely to happen.
I'll see if there's a way.
>As for the USB input with Poly connected. It isn't physically possible. Poly is the same width as Mojo(1&2) and it's interface is via the 2 x Micro USB connections. One for power pass through, the other to share the data. The Micro USB on the Poly simply provides power for Poly, or Poly and connected Mojo.
I would assume that there's enough space inside of the poly to add a small 'splitter' so the datalines can be hijacked if a micro USB device is connected to the Poly. I'll look into this as well.
>For the sound quality though, I can't rate the combination highly enough
I have replaced my ifi idsd diablo with this set today. right now it's charging. seemingly the first poly I picked up did not have any wifi capabilities. tried resetting, tried charging, updating, some more resetting. nada. weirdly enough bluetooth did work.
>Poly always drain batteries,
not fantastic, but probably not a problem either.
>When Poly is charged from the very first time you can not turn it off (look at previous point to get the full picture)
idem
>If you have a modern Wifi network around you be prepared to downgrade a lot including describing you security settings in order to make it work.
Seems to connect to my WPA3 AP. at least the one on my phone. not sure how often i'll connect it to my home wifi.
>GoFigure does let you play from SD card in very limited way, you need save a playlist files first.
I use MPD, so that's fine.
>You are right, it is quite expensive, poorly designed product that can quickly become brick unless you will bend and limit yourself to few very specific use cases. I wish it was other way around, but unfortunately it is not
I hope it will eventually be opensourced. Most devices I own that have been, enjoy a greater fanbase than those that have not been.
>To be honest and fair however, when you can make it work you will not regret it in terms of SQ. Another thing is that I got the same quality from a notebook. Mojo is also great via optical BTW but this option is also not possible when Poly is connected.
not possible yet. I'll have a look to see if it's simply a dimensional limitation, software, or hardware.
Despite the app dependency(and the app is not that great), I expect to have a lot of enjoyment out of this device. thanks for the tips!
-CH23
