Guy Fawkes
Check your GoFigure versionInteresting. My GoFiguer on Android tells me that Poly is up to date with 3.0.0 version yet there is "Update firmware" button available. Any idea why?
This is the same warning that I also receive, however it does not limit the correct display of all the contents of my mSDCan you share your settings for MAFA? For some reason, it is only seeing a small portion of my SD card. Under server it is saying "Limited support: missing optional commands; sticker, moveoutput, read picture, delpartition."
As I imagined, for some absurd reason the version shown on the Chord website is not the latest one available.
This thing had fooled me too because after the penultimate version of the GoFigure App (1.2.133) PlayStore does not offer the update of the App and I was left with the old version which did not display the latest version of the firmware available.
the latest version of GoFigure is as follows
and the only way to update it is to uninstall the currently installed version and perform a new download and installation from PlayStore, only in this way will you get the latest real version which will allow you to update to the latest firmware.
@Guy Fawkes thank you for help mate! I do appreciate it.As I imagined, for some absurd reason the version shown on the Chord website is not the latest one available.
In this case I am connected to my home network and MAFA automatically identifies the Host without the need to set it manually, same thing when I am connected to the shared network of my smartphone.
As I was saying, I also get the same warning and I never understood what it meant but I never looked into it further because despite everything everything works correctly and I can view all the files on the mSD.
I think your problem is due to something else, in the past it happened to me too and I had to format the mSD, reload all the files, insert it into the Poly, wait for the complete reading (until the multi-color LED stopped flashing ) then I entered the MAFA APP information, cleared the cache only after all this I started MAFA, waited for it to automatically load the Host and the content was completely visible with all the cover images set
I think this is normal, though not logical. Mine was the same. If you tap "update firmware", Poly will download the update. Not at all intuitiveInteresting. My GoFiguer on Android tells me that Poly is up to date with 3.0.0 version yet there is "Update firmware" button available. Any idea why?
the fact is that the MPD protocol is more powerful than the DLNA protocol to preclude it, Poly works better in MPD rather than in DLNAThanks, seems like a promising app but it is not reading my SD card properly. Bubble UPnP doesn't have that problem, so I guess I will stick with that for the time being. MAFA is also not reading my album art. Not sure why it hates me.
Dare I say it you seem to have a unique set of requests, none I can recall being requested beforethat's a lot of no's for a €500+€500 product...the only truly disappointing one is not having USB throughput with poly connected. I'll definitely have a look to see if it can be done.
thanks for the answers!
I know and agree that my requests are unconventionalDare I say it you seem to have a unique set of requests, none I can recall being requested before
We all have different requirements but alas not every product will suit everybody
I 100% agree with the charging times for all their products (same for the Hugo 2 / 2go), it's appallingly slow. But don't think the battery life is out of the ordinary.The battery life and battery charging times for the Mojo 1 and 2 and Poly are really poor for a product in 2023 / 2024. Very hard to sugarcoat that anymore...
