I got (and have been loving) the Mojo2 last month so I'm halfway there at least!
Things to consider before getting a poly:
At home you need good and stable WiFi. I personally added a Ubiqiti U6 lite to my router which massively improved WiFi in my home for every device. No issues with Poly, Hugo2Go and my RPi based network streamers.
On the go you can use your phone to provide a hotspot to Poly, and use that to connect, control and stream to Poly
On an airplane you can switch Poly into hotspot mode and connect your phone to Poly.
This allows you to play music from the SD card
EDIT: and from the files stored locally on your phone.
(thanks to
@Guy Fawkes for pointing it out)
Changing settings in Poly requires connecting to the Chord GoFigure App and always takes about 30s or more. If you use ROON you need to switch to “other” when you leave the house, and you need to change to “Hotspot” when you are on a plane
Indexing an SD card can take a long time and it’s sensitive to file naming. Some ppl had issues with it not finishing when special characters were used
Playlists for the files on the SD card need to be created manually with external solutions (I have not done it, Poly correctly identified the albums in my lib and I am using these)
Control of Mojo2Poly has to be done with a 3rd party app. I am using MConnect lite on iOS which works quite well and supports TIDAL and QOBUZ. The UI is however simpler than the dedicated apps.
Alternatively you can stream to Poly over Apple airplay using the original Tidal and Qobuz (or other) apps, but limited to 44/16
Sound quality is excellent but depends on source and transmission. My impressions:
SD > Qobuz >= Qobuz (airplay) > Tidal >> Bluetooth
Mojo2Poly is a little sensitive to RFI, I still get a bit of crackling in the background sometimes. Never an issue with Hugo2Go.
Bottom line: it’s a bit quirky but the sound quality and versatility are worth it to me. Aside from SQ I expect the pair to have a much longer service life than an Android based DAP. I once bought a used DAP only to realize that the Android system could not be upgraded and it was a PITA to find and install an old, compatible Tidal App, which shortly afterwards was no longer supported at all. That DAP was like 3 years old and had an MRSP of €1200…
I have been a mostly happy Mojo2Poly user for >6 months.
