Adding a simple ferrite choke ( some owners needed more, but I just needed one ferrite) to the usb cable, eliminated the brightness caused by RFI captured by the USB cable.
When using a Samsung phone as the usb input to the Mojo, I used to suffer from intermittent glitches when listening to music.
Adding just one ferrite choke to the usb cable removed 99% of those glitches.
OK no measurements, but cables act as aerials and naturally pick up RFI.
It is quite easy and cheap for Mojo owners to remove most RFI issues.
It is true that the Poly eliminates the RFI problem by using a direct connection from Poly to Mojo.
What I find difficult is the position taken by 'bits is bits' enthusiasts, who then deny that cables have any downstream impact on the ground floor modulation of DAC analog processing.
I totally understand the mojo picking up RFI and it is very annoying but it does not effect to top end of audio like some sort of EQ. It is audible interference being occasionally picked up when the smartphone is communicating.
And Poly does not completely fix this issue. If there is still a mobile communication taking place quite close to the mojo it will still pick the interference up.
When it comes to digital audio I am a bits are bits believer until someone can prove it to me otherwise. I am very open to that but so far I have seen no evidence that spending more money on a digital connection leads to a better sound.
Again if there are any recordings or measurements that you know about please let me know.
You can measure it with your ears if you choose different audio playback software. Different software is interesting the music file and sending its interpretation of that file differently. I can hear it, others can hear it. Install the demo of audirvana and choose kernel streaming to see if you hear a difference,
Okay,
There is no inherent sound to USB data. Bits is bits in this case. However, the USB chip implementation, connecting cable, source hardware, and destination hardware all contribute to signal interference and possible changes in sound quality.
The poly eliminates most of the above issues by directly connecting to Mojo. That is why we generally say the Mojo will sound better with the poly than directly connected to phone. That doesn’t mean that a phone connected to Mojo can’t sound as good as a poly.
Out of curiosity, what is the product/products you are MOT?
Whoa everyone, take a step back, and maybe sip a wee dram.
Those of us (maybe includes @ZappaMan) who have followed the Mojo thread since 2016, and have been part of the Mojo journey for 5 years.
The initial use of smartphones as the source for Mojo worked quite well, but was not perfect for everyone.
Poly does not have a cable connection to the Mojo, so in theory the Poly output is the Mojo input. No RFI is involved.
So Poly does not have a sound signature, but that does not mean that other usb sources to Mojo do have a sound signature (usually a negative impact)
YMMV but I am reading a lot of posts recently that imply 'bits is bits' and there is no need to consider RFI or other electircal noise.
Dunno why I never thought of using ferrite cores earlier. I had some sitting in a drawer from back when I was using them with a tube amp, just tried it out on a USB cable:
It does indeed reduce the treble glare vs USB cable alone. Most of the time I just use Mojo with Poly these days, but now I feel like a dunce for not trying this sooner!
Okay,
I believe Rob Watts mentioned that battery powered devices like phones are not an issue and thus you can use them fine. So no point using a Poly for that application if you are looking for a sound quality upgrade.
It is only with laptops and computers where the problem starts.
Well, in the release information for the latest version of Gofigure, Chord stated:
“ This update will align the application with 2go’s new firmware update arriving on Tuesday (18th May) and allow access to new features, such as automatic MPD playlist building. This firmware update will be closely followed by a Poly update.”
The 2GO’s firmware update was released on the 18th May, so I suppose the release/delivery of the Poly firmware update depends upon what Chord considers to be “closely followed”.
I will be keeping an eye on the “News & Events” section of the Chord website.
For all the bad press Poly gets as far as wifi is concerned... it always has a good connection in the backyard. My AK SP1000 is unusable without being close to the access point.
I’ve been very tempted to get a poly lately though I fear that in my excitement I’m arriving way too late into the party and we see a new version of mojo/poly soon…
Of course, this is only speculative so, I wanted to check with the community on thoughts over if it is a good idea to hop in the poly hype train at this point. Thoughts?
