SunRa Fan
I sympathize with you for sure. These are two well established streaming services and the Mojo/Poly has been on the market and selling well for some time now. The lack of authentic information on the configuration of these streaming combinations is appalling. At the very least, Chord could offer more detailed info here. Or even better, a Go Figure app which could act as a decent player. I did also restart the Poly following the setup, just because. After all, the source files, the app and the hardware are from three different companies, who don't necessarily care that much about each other, a recipe for just this sort of problem. There's a question on this very issue in the FAQ for Chord's streamer help section...unanswered. I'm sorry I can't offer more help. Chord has a YouTube video concerning configuration for Airplay streaming. Toward the end, they use the Tidal app to stream to the Poly...via airplay. Literally the only real reference from Chord on how to do this.
As an aside, if you're using the SD card slot on the Poly can you see and play those files with mConnect? How about files on your phone? Within mConnect, under the "Play To" tab at the bottom, have you tried tried refreshing the available UPnP devices? I have the Poly Renderer selected.
