DaYooper
I won't have my poly mojo until 2morrow so I haven't the experience but I'm watching.
Not sure what you are referring to. Is it just that some items aren't centred? This is what it looks like on an iPod Touch. Not perfect but quite useable.The latest IOS update for Gofigure has a bit of a UI bug (iPad mini4 IOS 13.4)
You can add iPad Air 2
https://www.moon-audio.com/content/pdf/chord/chord-poly-manual-2019.pdf
^^^This might help. You’ll likely need to do a “manual” set up, as your Poly is looking for the previous owners WiFi network (that’s what the flashing blue light is telling you). Do a Google search for “manual cord poly set up” and you should find some help. There may also be a YouTube video available to help.
My instinct is that your Poly has an early version of the firmware, which certainly made the setup less intuitive.Thanks
Thanks all. I've tried the manual setup but pressing/holding the config button for different amounts of time and it does nothing as far as i can tell (I'm also checking for any audio prompts but i hear nothing but bluetooth chatter) and the lights don't change. so I'm not able to get to any different modes as far as i can tell. at this point i think i've tried everything "intuitive" , i simply cannot access any different modes. Kinda frustrating.
The Poly FAQ is located here https://chordelectronics.co.uk/faqs-products/poly/
Probably your least stressful solution, will be to email support@chordelectronics.co.uk
@Matt Bartlett I am assuming that your support team is still operating at the moment, and not in lockdown mode.
Yes our support team are all working at home in isolation so drop an email to support@chordelectronics.co.uk to see if we can work this out. It does sound like this Poly is on early firmware.I would check with the seller whether it has been updated.
I know from my daily work that support teams can operate from home, in these difficult times, so follow Matts suggestions, and hopefully we can sort things out for you.I will reach out again. Thanks all. Seller is on covid lockdown and would take a week or two to respond generally
Ed
I know from my daily work that support teams can operate from home, in these difficult times, so follow Matts suggestions, and hopefully we can sort things out for you.![]()
After many months of uninterrupted service, my Poly did not connect in hotspot mode this morning. I successfully used it yesterday in network mode with Roon. Today, I powered up, switched from network to hotspot mode, and Gofigure restarted as usual. After that, I got the screenshot below with both the P and M LEDs a solid blue. I rebooted the MojoPoly and my iPhone and got the same results.
Any suggestions?
Connect via Bluetooth should be more then good enough for a podcast ?Quick query: I like to listen to podcasts but I cant seem to work out how to play them through my poly with my s9 galaxy. BBC sounds, Castbox, etc don't seem to see the poly whereas mconnect does when playing music. Am I missing something or is this functionality unavailable? Would seem incredible if it isn't.
