ZappaMan
Maybe worth ordering a sandisk card in the mean time, if a solution appears you can return it.Hi, It's a Scandic ultra64 gb. it's been previously used in a fiio dap( or A&K, can't recall). I reformatted it, as per chord suggestions to exfat,(it was previously fat32). There is nothing but music files on it.About 12 albums of so just to try the poly out.The files play fine via the laptop speakers. Initially I created a folder on the card to place the albums in. When that didn't seem to index on the poly, I removed them from a folder and left them individually on disc. thanks
I’ve had flakeyness with cheaper cards working for one thing but then not in poly.
If you’ve followed chord instructions and reformatted the card, then added flac files to it, I suspect it’s an issue with the card.
