Chord 2Go & 2Yu Wired/Wireless Network streamer and S/PDIF adaptor - Official thread
Dec 6, 2024 at 3:09 AM Post #6,406 of 6,453
Hi there, has anyone experiences drop outs in the connection of the 2go? As in it plays the first few seconds of a song and then skips to the next one until it fails.
Specifically, I'm using it as Roon endpoint fed by FLAC files stored on my NAS (the speed of my home network is normally excellent).
Does your Roon work with other endpoints OK? I usually use the wired connection on 2Go but Wifi works fine too. I did have an issue similar to the one you are describing when I tried the Roon smart playlists feature but I turned that off and its fine now.
Dec 6, 2024 at 10:48 AM Post #6,407 of 6,453
Is your Roon Core on Ethernet?
Roon tends to work better when the Core is wired, which is what Roon recommends. (because wifi is only half-duplex whereas Ethernet is full-duplex and Roon is very demanding on the Network)
I had your issue repeatedly until I put my core on Ethernet - this despite having a decent Asus router that was located less than 2 feet from my Roon Core PC and no other homes near me.
I still get occasional dropouts (With 2Go only. Other endpoints are fine) with the Core wired but not often. Restarting my router and Core usually resolves it for a while.
Dec 6, 2024 at 10:55 AM Post #6,408 of 6,453
Same here. A symptom of the router needing restarting is the usual "Tidal/Qobuz media is loading slowly" error message.
Dec 7, 2024 at 12:47 AM Post #6,410 of 6,453
Yeah it’s all hard wired: the core is on a Roon Rock, hard wired to the router.
All my other endpoints, wired or wireless, don’t have any issue… but the 2go
Dec 7, 2024 at 12:48 AM Post #6,411 of 6,453
Yes, very common because 2go uses the very congested 2.4GHz band, where bursty packet loss is common from interfering networks nearby. Roon RAAT does not like that at all because it is optimized for low-latency synchronous play that can't accept higher packet retransmit delays. I've given up on using my 2go in the congested city wifi environment, and exiled it to the country, where I can use it outdoors because neighbors are sparse and far away.
I actually changed the 2.4ghz channel to 11 and now it seems like it’s working like a charm again
Dec 7, 2024 at 12:49 AM Post #6,412 of 6,453
Yeah all good with all the other wired and wireless endpoints…
Dec 7, 2024 at 12:50 AM Post #6,413 of 6,453
Dec 7, 2024 at 12:52 AM Post #6,414 of 6,453
The router is brand new and it’s a very high performance wifi 7 ASUS… but yes I’ll try and restart that too.
Dec 23, 2024 at 12:03 PM Post #6,415 of 6,453
Roon works much better with the Core connected via Ethernet. Wifi can cause dropouts due to its half-duplex nature, while Ethernet offers more reliable, full-duplex performance. I had similar issues until I switched to Ethernet, even with a good router nearby. Occasionally, I still get dropouts with 2Go
Dec 23, 2024 at 6:32 PM Post #6,416 of 6,453
does the firmware update fix the 2go dropout issue?
Dec 23, 2024 at 7:11 PM Post #6,417 of 6,453
Dec 23, 2024 at 7:55 PM Post #6,418 of 6,453
The dropout issue is a "feature" of the very mediocre WiFi on the 2go, restricted to 2.4GHz and lacking anything like an external antenna.
Dec 23, 2024 at 8:43 PM Post #6,419 of 6,453
Are you trolling us? 😀
no, i actually dont know of this product im actually about to blindbuy a hugo 2 2go but the seller says the 2go suffers a wirelessdropout, its only 1k usd for both so not bad for blindbuy
Dec 23, 2024 at 8:54 PM Post #6,420 of 6,453
the dropouts can be alleviated with a really good WiFi network and some channel configuration to reduce collisions with neighboring networks, but overall, I'd not buy one even for $1K for WiFi use. It works great as an Ethernet DAC/amp, though ;)
