dasadab
- Nov 14, 2016
Thanks a lot. Doing more research on the Roon ecosystem, I realize I need a Roon core device or it’s no go with Roon, unless I want to use my computer, which won’t really work because I don’t want to keep it on all the time. Therefore, it doesn’t seem Roon ads much unless there is some functionality with streaming Qobuz or using the Hugo’s internal SD card that I’m not aware of....the problem is the opposite. If you have the iPhone volume set too low, then you will have lots of noise as the signal to noise ratio becomes intolerable at around 5-6 mark on the iPhone.
