ubs28
- Aug 2, 2013
Hmm...
Updated firmware to 1.0.3. Now I can't connect to the 2go with Gofigure (on my iPhone). All was fine before the upgrade.
Connects fine to my Poly.
Have deleted Gofigure and reinstalled. Have carried out a reset to my 2go using the config button. Nothing.
Eventually managed to connect to 2go via Gofigure for a brief 5 minute period, but then lost connection and haven't recovered it.
Oddly, I notice that the Network light is flashing blue and green alternately when in hotspot mode (shouldn't the 2go indicator light be doing that?). And the 2go light remains off, unless I load a SD card in which case it flashes green to show it is indexing.
@Matt Bartlett - I've sent a message to Chord support but if you have any suggestions that would be much appreciated.
I had the same issue after updating to 1.0.3. My Chord Poly is detected by the GoFigure app, but the 2GO was not detected. Also nothing worked (DLNA / Airplay). So it was basically a brick.
Perhaps try an other factory reset to see if the 2GO will be detected again by the GoFigure app as that is what fixed it for me.
