Mang Domeng
- Feb 11, 2016
'Ello Head-fiers,
I wanted a pair of good workout clip-on headphones, and after much digging here I (like many probably) grabbed a pair of Koss Ksc75 from ebay for around $20 all included. The packaging seems completely genuine but...
The sound it produced is suspicious, the treble is surprisingly clear but not painful, the mids are fine, but the bass is problematic on both sides. Whenever I crank the source (I tried a laptop source, a sony stereo source, and a sony walkman source) to an appreciable volume, the base and vocal in songs with beats start becoming severely distorted; it sounds like a cross between cricket-chirping and metallic oscillations. This really kills the sound fidelity and makes it unbearable to listen to.
Regardless, I later committed and applied the Kramer mod on with success, overall the sound DID improve but the distortion was still there. It seems to be a driver problem.
Has anyone else owning a Ksc75 experienced this phenomenon? If so, is it remediable or do I have to return it for another one?
Currently I'm burning it in with some beat-heavy songs, hopefully that'll reduce the chirping distortions but if not, I'm at a loss.
Thanks!
I noticed the same sound in my left earpiece when I play bass-heavy tracks. I think I found the solution to your problem. I just tried doing a quick blow of air with your mouth on the driver with the foam on it, you will hear the driver diaphragm will press a bit. After I did that the rattling, chirping sound on the lows are gone. I was already considering replacing the drivers with my damaged kph30i but since it is fixed I will save the other driver for another mod. Hope this will fix your problem after 9 years. Cheers!
