Look at what came in!
How does it sound? Can't wait to hear your impressions!
Just some quick impressions.
Firstly, the headphones is very very light, and while the constructions are simple, they feel sturdy enough. I'll take some photos later on. My only worry is the pleather ear pads which will eventually peel. Will source for leather ones.
Sound-wise: This definitely veer more towards the neutral, flatish sound signature. I did a short comparison against the Verum One headphones and the Verum sounded slightly warmer in comparison.
The treble can be tiny bit peaky at time, but I don't really detect any sibilance. The bass is what impressed me the most. It's not a bassy headphones, but it reaches deep into the sub bass easily. I love the bass presence which does not leak or overpower the mids.
Overall, it's not a gamechanger or mindblower like the Raal headphones, but it is just a very very good headphones that perform better than its price tag will suggest.
I will try to compare it to the MrSpeakers Ether headphones (bought before the name change).
Side-thought: I wonder if the amp is the one holding back the headphones, might ask the seller if he has plans for a better amp.
Came across this and I might get one to test. Will probably cost me only $10 anyway, but I'll need to get the DC supply separately. Accepts USB and Bluetooth.
@svperbia for the left and right output to the amp, how should I solder the resistors? 1 x 1ohm resistor for each cable? So a total of 4ohm combined for all cables?
Probably going to want 4 ohm resistors, as series resistance is additive, each circuit (one for each side) will have a 4.1ohm resistance, which should be within the specified range for most amps.
I am not sure what kind of output power the amp you're picturing can push, but you're going to want to keep that in mind when choosing a resistor to use. Small resistors won't handle much heat and will burn, better to choose a wirewound one like shown in the video I linked earlier (https://www.amazon.com/uxcell-Mounted-Aluminum-Wirewound-Resistors/dp/B008ML0LE4/) something like this.
Each side of the headphone can be seen as a circuit, current flowing from positive to negative, through whatever circuit you use to connect them. In your case, that circuit would be a 4 ohm resistor to load match and dissipate heat and the 0.1 ohm ribbon to create the sound, in series.
You're gonna want to attach a banana plug into the positive end, followed by a resistor, followed by the positive side of the ribbon, then wire the negative side of the ribbon back to the negative on the amp. The order of the resistor shouldn't matter in theory, it should be able to come before or after the ribbon without changing the total resistance of the circuit.
I assume the ribbon is wired with a 3.5mm mono, but I don't physically have my headphones yet so I can't guarantee that.
Assuming 3.5mm mono, you have a lot of options in wiring here, you can choose something crude yet easy like this , or if you want to hide the mess of resistors away somewhere and use the standard cables that came with your headphones, you could use something like this to solder leads directly to an output 3.5mm which you can then directly plug your headphones into. In my experience in DIY headphones and repair, I'm fairly comfortable and have found good success with the second option, but this will be my first time using the 3.5mm jacks out of a speaker power amplifier.
I strongly recommend watching and understanding the stuff in this video ( ), as he directly shows wiring and circuit drawings for doing exactly what we're trying to do here on his own diy ribbons. I'd also recommend applying great caution here, and not even attempting it if you're new to circuits and electrical work. Even though this is just a really simple 'resistor in series', being very careful is always good. The amount of power in some of these amps is not negligible, and could easily physically damage the ribbon or yourself.
You can get USB 5v to 12v step up converters on eBay inexpensively. e.g. https://www.ebay.com/itm/392874960264Thanks for the detailed explanation of the amp and adapter that you made. Good to know that what I envisioned in mind was exactly what you did.
I can easily buy a small complete power amp at 30W+30W that is portable size but the issue is they're mostly DC powered. I'll be interested to see how you hook up a power bank to your amp.
EDIT: Just a thought, will hooking up a power bank to the amp via a USB-to-DC cable work? Assuming I can find one wihich supports the right voltage (looking at the amp spec, I'll need 12V to get 30W per channel).
