Can anyone recommend cheap (<$50) on-ear cans for commuting? Good isolation is required. Earcups must pivot.
My (quite old now) MEElectronics HT-21s are having wiring issues from L to R and I'm not confident I can replace that wire myself, so I would like to buy something to replace. I'm seeing lots of recommendations here for open and semi-open and that just won't do for riding the subway/bus. Many thanks in advance.
[EDIT1] Has anyone tried the Xiaomi Mi Headphones Comfort? Found just one external review: https://www.thephonograph.net/xiaomi-mi-headphones-comfort-relaxed-tdser02jy-review/
[EDIT2] Leaning toward Takstar Pro 82, which seems to be a community favorite here. Closed design. A little over my target price. Is there anything below $50 that competes?
I personally don't like the Pro82 in general but even if one did I'd be hesitant to recommend them for commuting as you've got the choice between tight bass with very little impact (vents closed) or very low quality bass with high impact (vents open). For commuting I'd say that vents open is a must and the sound quality is very average that way imo....
Edit: There's not easy to get a good sounding full size headphone for less than $50 though so I think it's rather a matter of how bad sound one can accept and what tradeoffs one is willing to do.
