I have the shp-9500's, and can compare it to the status audio cb-1's.
Highs - Winner = Shp 9500's
Listening to the shp 9500's highs are just amazing. Brilliant actually. Everything is so clear and strong. Never ever had it have a painfully high pitch, but it feels in a way, sharp? When compared to the cb-1's (which also have great highs), the cb-1's sound veiled. It's kind of like, the treble satisfaction of the cb-1's just can't reach the impact of the shp 9500's. If you were someone who could only hear highs (bless your soul), and tried to do a direct ab comparison between the two, you would double the volume on the cb-1's, and it still wouldn't feel as satisfying as the shp 9500's. The highs on these cans seem to pierce through, not painfully or in anyway negative, but just pierces through and comes out so cleanly. If highs are your thing, the shp 9500's are undoubtedly better. The cb-1's highs are great too. Just not shp-9500 level. The highs on the cb-1's are still a decent chunk better than average . Just doesn't have that clarity and treble (impact) that the shp 9500's have. The cb-1's are in no way bad at highs, it's just that in the sea of music, the highs on the shp 9500's are like clean incisions piercing through the masses of water so beautifully that even Moses couldn't compare.
Mids - Winner = Shp 9500's
Mid's on the shp 9500's are also very good. Equally as good as the highs. Just amazing. I honesty think that the cb-1's are good here too. I feel as though the 9500's do a slightly better job at mids. When listening to Breezeblocks by Alt-J, the mids/vocals just sound better on the shp-9500's. The voice is raspier on the shp-9500's than on the cb-1's. Not raspy in the sense of $1 earbuds with static, but like, it seems like an extremely accurate portrayal of the artist's voice (This guy has a super raspy voice, and I imagine the shp's play his voice the way it exactly sounds). Both headphones have good detail, but the shp-9500's are open back, and I'm sure the sound stage really helps it here. I do think that there could be a tad more emphasis on the cb-1's
Lows - Winner - Status Audio CB-1's
The bass on the shp 9500's suck. Straight out. It's bass anemic, lacks sub bass, mid bass, and bass impact. The bass is just weak. It's not sloppy or anything bad in that sense. It''s just not there. If you dislike bass (if that's possible), then these are perfect. The bass, aside from quantity, doesn't have super glaring issues. If there were simply more bass, the bass on these would be fine. The quality of bass is fine, there's just not nearly enough. I wouldn't call myself a bass head, but these definitely lack bass. The bass on the cb-1's are good. Punchy, strong, not over bearing, not sloppy in the slightest. It's quite good bass actually, and while it may not be enough in quantity to satisfy a bass head, the quality of bass is good enough to please anyone. The quantity of bass on these cans is ever so slightly more than neutral. It's good. The cb-1's are advertised neutral cans, and despite being a tad (I mean incredibly small) bassier than completely neutral, I doubt anyone would confuse them as bass heavy.
Build - Winner = Shp 9500
Shp-Actually built amazingly well. I've sat on it twice to feel it flex and survive with no damage. Does make noise if you shake it. That is the only negative. Everything else is perfect. Build quality is top notch. Feel too good to be true. They do look a bit ugly. The cb-1's greatest weakness might as well be build quality.
Cb-1 - Built okay. Plastic band is a HUGE no-no for me. If you don't care about plastic bands then the build is very decent. Cups are like a nice painted on aluminum or something. Takes a plastic fantastic approach, but still feels quite well made. Solid plastic.
Comfort - Winner= Shp 9500 / CB-1's (debatable)
SHP- Low clamp force. I love it. Huge pads. More surface area = less pressure in one spot = more comfort. I just love it. Pads were a bit shallow so I modded them. Headband is well padded, could be a bit softer material but I still love it. Very good comfort. Velour/Fabric. I actually worship pleather/leather though, but it wouldn't work for open backs.
Cb-1's. Very good. A decent chunk clampier than the shp's, but it's only a tad too clampy for me (fyi: I hate clamp more than anyone. My headphones are stretched out to be 1 inch thicker than m head. If the cb-1's are only SLIGHTLY too tight for me, it's an appropriate amount for others), which is probably perfectly fine for anyone else on earth. Amazing ear pads. Good top padding. I might be a bit biased here because I love pleather.
Appearance -Winner = CB-1's
No question. They look sexy. The shp's are ugly.
Portability - Winner= CB-1's
Smaller. They fold. They are closed back. They look nicer. The shp's should only be used at home
Sound sig
SHP's - Bright? Absolutely brilliant at mids/highs. Bad bass
CB-1's - Neutral. Jack of all trades. Actually very good at everything. Not having as good highs as the 9500's isn't a weakness. It's more of a given. Mid's could be a bit more emphasized. Detail is fine. Bass is good.
Sound Stage
I'm terrible at distinguishing sound stage, but I do know that the shp 9500's have amazing sound stage. Wide and fun. The cb-1's have decent sound stage for a closed back. Better than average.
Winner-? You decide. You want something closed? cb-1's or other closed back options. You're only gonna use these at home? Give the shp's a try.
Personally, I would pick the shp 9500's over the cb-1's. I used to think I'm a bass head. These make me question if I am. I don't even mind the lack of bass on the shp's thaaat much. The highs and mids really make up for it.
I know someone like Pharmaboy LOVES bass. If you are like him, the 9500's are just not for you. Even if you can afford to use an open back for home only use. If you really want to try a budget open back, but love bass (open backs tend to have bad bass anyways), look for the takstars hi2050, or their isk clone, or superlux line up, or save up for a Sennheiser 518.
If you want something that is a great headphone, with no weaknesses (EXCEPT THAT PLASTIC BAND), get the cb'1s. Nothing says you can't use them at home, but you can also use them outside.
This is my first review. I'm not that experienced in the audio world. I'm sure a made a lot of mistakes/used wrong terms. Take my advice with a grain of salt
