I've bought a few IEMs now, I wouldn't describe myself as a connoisseur by any sense of the word, but I am absolutely in love with my Joyeroom E107s that someone recommended for their small and unassuming profile (both in appearance and functionality). They're decent isolators and I've had no issues with build quality. They're also really cheap!
I did buy a pair of Dunu DN-1000s as well: whilst they sounded notably better (I do like the v-shaped signature) and they were very decent, unfortunately within two months the right side has stopped working properly, hence I'm returning them. They were also quite heavy and notable whilst in your ears. Greatly satisfying IEMs in terms of SQ for the duration that they worked, but I've established that I needn't spend that much for something that will fit my needs, especially due to really feeling it with extended periods of wear.
The Tennmak Pros I also had were lacking in build quality and have fallen apart fairly rapidly, plus I prefer the straight-down profile. A pause button is preferable but not essential. Those Joyeroom's were certainly the best purchase thus far (in terms of being economical) and I'm probably going to buy another pair for the sake of it. They're great for working with!
However, I'm curious if there's anything comparable with a little more power, as I believe the drivers are only 6mm. Ramping up the volume on my i6S can cause a little distortion/harshness (though it's pretty much fine). Is there anything with similar isolating qualities and lightness (they fit very snug in your ears which is great for sleeping as well) whilst also being cheap (the Joyeroom's were very cheap @ £8-9ish). I don't mind paying a bit more (up to £20ish give or take) as long as they have similar qualities (but with a little more power and depth).
Is there anything out there that fits that criteria? The E107s sound signature is more than fine for my tastes: I do primarily listen to electronic genres but wouldn't want a 'bass-head' head-phone per se, just something that is preferably slightly/or v-shaped. I like the sound signature of the E107s (my ears are more than happy with them) but at the same time if there's something with a little bit more oomph then do tell!
EDIT:
I'm considering the Joyroom JR-E109, audiobudget rates them highly (even more so than the E107s), but there's not many reviews on them.
Any recommendations? Cheers all.
Maybe the MEMT X5
