Nimweth
@Hawaiibadboy just received his TinHifi T4
OMG.. Really this mid 2019 is the best chifi season ever
*edit : they called TinHifi now instead of Tin Audio, forgot bout that
What's inside? 2xDD? 1DD+1BA?
I don't know about you but your comments are still pushing the stereotype that the Blon 03 don't fit well still.just wanted to share my findings regarding blon 03.
key thing is the fit. I'm blessed that I have JVC Spiral Dots sized M/L and L in my stash.
M/L is the right fit for me but L is oversized . For Blon's case, I need to use size L and with this the isolation is top notch.
Those that mentioned that it doesn't isolate well hmm.. this might be secret that you may have missed or maybe this config just fits my ear canal.
I went through my ear tips stash . those from my chifis , double flanged and even foam tips. all nada.
oversized JVC Spiral Dots are stars aligned with the BLON.
Or, do you need the JVC's for isolation alone?
It sounds like they need to rework this iem to make it good for everyone, without the need for different eartips.
I think the Blon BL-03 are a mixed bag, but not worse than the EP10.That would be impossible with any iem. Everyone has different ear anatomy.
If you are annoyed by having to try different tips maybe you should try earbuds..... but then you would still have to decide if a certain model is better with foams, no foams, double foams, donut foams, donut foams on top of regular foams....Plus the foams are available in different colors
...and then there are headphones with the endless talk of what pads are best.
This is Headfi.
OPPTY knocks more than once and DRIAMS really do come true.
I almost threw the box away yesterday but....I kinda think there is a coded message in there so will keep it
the cables are functionally ok, I prefer those that are flexible ( not the stiff type ).
If you wanna upgrade, you should try SPC if you prefer more brightness else pure copper.
Peace!
Another update, my Tiger TRN cable came and combo-ed with the Blon.
I think it helped to improve the highs a tad ( which I like ) while maintaining the bass
Please share a photo of how they look together.
