ozziecook
Cent. Awful. There. I’ve gone and said it.Can you share a link? The only ones on Amazon i see are $129.
Also, CNT1 is one letter away from a very bad word in the English language.....
I was thinking the Millennial mantra: can’tCent. Awful. There. I’ve gone and said it.
No matter how many alternative names you guys suggest, if I get a pair of these I will always call them the real version, if not out loud, at least in my head.CNET? They’re bad, but they’re not that bad...
CNT is a well established scientific abbreviation, so any problems with it should be brought to those scientists rather then IEM designersI was thinking the Millennial mantra: can’t
Yep. eBay has em for cheaper but the only ones I see on Amazon are $129USD. The blon are all over the place.Those links are for BLON BL-03 though, not the Semkarch CNT1.
I did recall seeing amazon sellers hawking the CNT1 last week at sub 50 bucks, but seems the only ones there now are around 100 bucks. =(
Chifi measurements I took for comparison and analysis (red line, ignore green line)
Well...
Anyway if you dig those out again here are a few songs/genres that (to me) sound better on CNT then anything else I have listened too.
No the green line is just ambient noise after I removed the iem from the mic. Ignore itIs the green line show THD?
is there any budget IEMS u can recommend for depth soundstage and airyness?Apparently, I like them both the same but for different reasons. Both are excellent choices! So, if you like how a dynamic driver sounds with low sub-bass, luscious and spacious midrange, and transparent-like treble, then your best bet is to get the BLON BL03. But, if you're interested on how a hybrid might sound like with dynamic drive sub-bass which carries a punchy sonic-like signature and raw but fresh sounding BA midrange followed by exceptionally detailed BA treble, then your best bet is to go with the CCA C12. I don't see any weakness' on both other than the fit. So, in this case it's a personal choice that I can't make for you. Honestly, if you ask me? They are both incredibly balanced with extended lows and highs, but sound different making them unique to each other. So, I would personally suggest to save up for both, IMHO!
Hope this helps...
-Clear
The Blon and the C12 are already in the budget segment.is there any budget IEMS u can recommend for depth soundstage and airyness?
I have to agree about the great, well studied and solid shell.TRI I4, probably the most well made, beautiful and comfortable metal housings I've seen so far:
