Chinese / Asian Brand IEM Info Thread
Sep 30, 2019 at 2:10 PM Post #26,972 of 33,689
I believe, with the right ear tips and seal, the BLON BL03 can do this very well on a budget level, IMHO. :wink::thumbsup:
...though, they're not the best on a technical level.
Exactly, with the right tips and seal it has a great soundstage and airy vocals. With tips that do not seal, prepare to be frustrated that they don't live up to the hype. If your ears are too large for the included cable (tugging on the buds) swap the cable too. Think about your music preferences too if they match the BLON.
Sep 30, 2019 at 3:23 PM Post #26,973 of 33,689
What are the right ear tips for these?
Sep 30, 2019 at 4:40 PM Post #26,974 of 33,689
Sep 30, 2019 at 5:25 PM Post #26,975 of 33,689
I am using the large starline tips that came with any kz iem. IMG_20190930_142411.jpg
Oh and if you noticed, I cut the stem of the tip that came from BLON (it is crappy anyway) and cut them in half and fitted them to the bottom of the stem of the iem. It makes the starline tips not going all the way to the bottom stem of the iem.
Sep 30, 2019 at 6:14 PM Post #26,976 of 33,689
I feel like I should clarify some things about the Magaosi DQ4 for everyone. I've been getting alot of pm's about them, so I feel like maybe a public post would be valuable.
I was pretty smitten with the DQ4 whenever I first got them. I found them pretty easy for me to get a good seal, and also were easy for comfort during long listening sessions. I was coming from a pretty dark sounding daily driver in the Toneking T88k, and was blown away by the detail level found on the DQ4. Another thing I loved was that I could turn the volume very low and still get good bass response and very good level of details.
I started realizing some of their short comings whenever another member received his pair and found them to be horrible for his preferences. We chatted and came to the conclusion that he likes listening to music LOUD, whereas I'm a lower to moderate volume user.
I did some additional testing and found that the DQ4 loses a ton of it's best qualities by louder listening levels. The treble overtakes the signature and also introduces grain and glare in the treble.
I couldn't believe how badly they sounded to me just by increasing the volume levels to a higher volume! For context, the DQ4 triggers my high impedance mode on my LG V40 and I use them at volume 27-31 with that setup. I found that the sound fell apart at any volume over 35.
I would still recommend them to someone who craves an energetic sound and isn't treble sensitive. But, I will warn that your level of volume usage will play a HUGE part in your enjoyment of them!
Sep 30, 2019 at 8:21 PM Post #26,977 of 33,689
Hey did you manage to get good fit with stiffness of bt20 earhook?
Sep 30, 2019 at 8:46 PM Post #26,978 of 33,689
Oct 1, 2019 at 12:13 AM Post #26,979 of 33,689
Thanks for the sacrificial stem cut tip. I had a maddening time with the fit and that was one problem.
Oct 1, 2019 at 1:03 AM Post #26,980 of 33,689
This should explain why I simply couldn't listen to them. I always listen to higher level volumes ( I don't have good hearing ) and they sounded so much worse than KXXS and P1, and was really frustrated with them, that I simply sold them for half the price.
Oct 1, 2019 at 2:24 AM Post #26,981 of 33,689
This is what im always talking about, not only for DQ4, but there are a lot cases about this. A very good balanced iem, in low volume usually treble side are not so lively, but once you crank up the volume, they are become more balanced, trebles have sparkles without dominating other frequencies. Like BLON BL-03 in this case, if youre listening in higher volume, you will starting to hear trebles more but still safe and balanced in high volume.
Oct 1, 2019 at 2:34 AM Post #26,982 of 33,689
Thanks @thejoker13 and @DynamicEars for pointing that out. That's something I realized in some of my IEMs too. Is there a technical reason why the sound signature changes with volume? Don't all frequencies linearly increase with volume?
I find that it happens on the TFZ No. 3 too, the treble becomes brighter with higher volume and sort of encroaches into other frequencies, especially the 8khz peak. Do u find it so @DynamicEars , since u also have the TFZ No. 3?
Oct 1, 2019 at 2:47 AM Post #26,983 of 33,689
Yes, so like bass frequency the different of each step in volume isnt not that big, but for higher frequencies the increment of each step volume are bigger. until we listen in higher volume, higher frequencies are overlapping bass frequencies. This is happen with a lot of iem. For multidriver maybe because of different driver take different power to drive, but sometimes it happen on single DD iems too, I cant figure out exactly what happen but Im hearing that, so its not only me then. I guess it is caused by resonance of sifferent frequencies in human anatomy? Im not sure so I cant talk much, but I always experienced that, so i prefer more tamed treble, when i listen in high volumes, they are become so balanced
and yes, same case with TFZ no 3
Oct 1, 2019 at 3:15 AM Post #26,984 of 33,689
Yes, all frequencies linearly increase with volume, what doesn't however is your perception of these.
https://en.wikipedia.org/wiki/Loudness
Oct 1, 2019 at 5:01 AM Post #26,985 of 33,689
Thanks for the link, I've learnt something new today
"The sensitivity of the human ear changes as a function of frequency, as shown in the equal-loudness graph. Each line on this graph shows the SPL required for frequencies to be perceived as equally loud, and different curves pertain to different sound pressure levels. It also shows that humans with normal hearing are most sensitive to sounds around 2–4 kHz, with sensitivity declining to either side of this region. A complete model of the perception of loudness will include the integration of SPL by frequency."
no wonder that TOTL iem always have little dip around 3 khz to compensate the sensitivity. So bottomline, loudness are linearly increase, but our sensitivity against certain frequency area is different. This is really affecting much in tuning the IEMs and in how loud youre listening then. My long time curiosity got answered today.
