I just got the audiosense t260 which is just a 2 knowles armatures, but man does it sound super satisfying!
Chinese / Asian Brand IEM Info Thread
- Thread starter Brooko
SuperLuigi
Sorry if a bit off topic, but does anyone have any experience /suggestions for a USB-C to 3.5mm headphone jack for a phone?
RikudouGoku
Member of the Trade: RikuBuds
Hidizs sonataSorry if a bit off topic, but does anyone have any experience /suggestions for a USB-C to 3.5mm headphone jack for a phone?
The Blon BL-03 is so last week ; which I do have and they're good, with the right tips and o-rings (to keep the tips from slipping down the already short nozzles). But for the dimensions of my ears, I have to twist and then re-adjust, to get a good seat.Push that button, the BL-03 are awesome
Agreed with this. @1clearhead You can always use it as a reason to stop your hype in buying them
I use the Tempotec/Hidizs Sonata HD too. Flash it to mode D which gives it the best sound quality (see the thread on Sonata HD for more details).
RikudouGoku
Does Linsoul.com have a sale on 11/11? I am being pulled into buying the Peacock Audio P1 by its looks....does anyone have it and the TFZ no.3 to compare?
Slater
If you’re on a super budget, the dodocool one is like $10 on Aliexpress and works great. It used to be $40+ when it 1st came out.
For $10 you have nothing to lose. The Aliexpress reviews on the USB-C version are overwhelmingly positive.
Unfortunately I got the lightning version of the same dodocool adapter. And despite supposedly being iOS/Mfi certified, I get the “this accessory is not supported” message after 2 minutes (at which point it stops working). I am able to use it on my iPod Touch (iOS 9) without getting blocked though. It is built well and works great.
FastAndClean
Previously known as presata
i have to sell my Semkarchy
i am loosing seal on my left ear after an hour or so
ScottPilgrim
Umm... why not get the one from apple? Since you’re in Calgary your local apple store should have it. Dirt cheap too.Sorry if a bit off topic, but does anyone have any experience /suggestions for a USB-C to 3.5mm headphone jack for a phone?
SuperLuigi
I've read they can be hit and miss for android phones. Lots of comments/reviews saying the volume is very low when using the apple product with an android.
Slater
Despite not having an Android phone any more (nor anything USB-C), I do see people recommending the Google Pixel adapter quite a bit.
One advantage of the $10 dodocool one I recd (over a basic adapter) are built-in volume & music controls, plus headphone amplification.
P-l-e-a-se, let me know how you like the BLON BL-03 once you get them! ...I must convince myself NOT to push the BUY BUTTON!
BL-03 is decent sounding. I mean, i guess for $30, its actually quite good. The fit is really bad for me though. I don't play well with shallower fit IEMs. I find that it's a tad bright given there's a peak at 8K and that is a sensitive peak for me if it's not an even treble response, which this isn't.
I saw on the Linsoul Discord: No they don't have an 11/11 saleDoes Linsoul.com have a sale on 11/11? I am being pulled into buying the Peacock Audio P1 by its looks....does anyone have it and the TFZ no.3 to compare?
But who is to say that they may not change their minds, if other E-Commerce curators (outside of Aliexpress) decide to have parallel sales, to 11/11
pfloyd
- Oct 25, 2004
For me, by fitting the core of a smaller tip inside the core of a large tip, the tip stays higher on the nozzle, no matter how hard I shove them in my ears, providing excellent fit. These things are amazing!
FastAndClean
they are fast and clean
Total: 14 (members: 0, guests: 14)
