Chinese / Asian Brand IEM Info Thread
post-15189718
Post #26,386 of 30,383
pfloyd
For me, by fitting the core of a smaller tip inside the core of a large tip, the tip stays higher on the nozzle, no matter how hard I shove them in my ears, providing excellent fit. These things are amazing!
post-15189877
Post #26,388 of 30,383
Slater
Cincinnati, Ohio USA
post-15189879
Post #26,389 of 30,383
mbwilson111
Reactions: Slater
post-15190572
Post #26,390 of 30,383
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Estonia
Estonia
BL-03 is decent sounding. I mean, i guess for $30, its actually quite good. The fit is really bad for me though. I don't play well with shallower fit IEMs. I find that it's a tad bright given there's a peak at 8K and that is a sensitive peak for me if it's not an even treble response, which this isn't.
How`s BL-03 against KPE ? Your impression about it leaves me little worried...
post-15191295
Post #26,391 of 30,383
rayliam80
TX / RP
TX / RP
I got the Blon BL-03 last week. I have no problems with the shallow fit. I'm using small Auvio tips with a little bit of foam stuffed in them. I went with a cable with straight connectors also, Y-brand 8 core black spc cable, and removed the ear hooks from them. These just melt into my ears and never pop out. I find them more comfortable than the Tin Audio T2 or P1. I think I like the Harman Tuning, or what appears to be close to it. I do noticed that it can lose the plot a little with more complex or heavier rock tracks with distortion. But for less complex music, there is still a lot of detail and the sub bass presence is something I've missed too in other IEMs. These are a little brighter sounding than my T2 but has deeper sub bass. The T2 is a bit darker sounding, not really veiled, just a bit smoother overall. But the BL-03 since I received them have had a lot of ear time just because of the fit I'm able to get.
post-15191349
Post #26,392 of 30,383
Dani157
India
India
I saw on the Linsoul Discord: No they don't have an 11/11 sale
But who is to say that they may not change their minds, if other E-Commerce curators (outside of Aliexpress) decide to have parallel sales, to 11/11
You can buy it from LuckLZ store on AliExpress they'll be on discount on there. They're a decent store with good consumer support.
Reactions: petan970
post-15191385
Post #26,393 of 30,383
snip3r77
WOW T2 is darker than BLON3 ?
post-15191417
Post #26,394 of 30,383
RikudouGoku
Sweden
Sweden
Just wanted to ask for those of you who are using double flange silicone Eartips, which ones are you using? For example for single flange silicones you have a lot of good options such as the spinfit and the spiral dots but I have no idea about double flange. I am using spinfit CP145 with all my iems right now and I have also tried their cp240 but that had a terrible fit for me.
post-15191506
Post #26,395 of 30,383
rayliam80
TX / RP
TX / RP
It could be my choice in tips. I've been switching to foam stuffed Auvio and KZ Starline tips. Or it could be that my T2s are a bit dirty and might need a nozzle soak in a tiny bit of hydrogen peroxide....
post-15191516
Post #26,396 of 30,383
SciOC
Midwest, USA
Midwest, USA
TRI I4, probably the most well made, beautiful and comfortable metal housings I've seen so far:
Wow. I don't usually care about how things look, but those are gorgeous. Do they sound decent? Might be a good lawn mowing pair for me if they're not bad...
Reactions: peter123
post-15191601
Post #26,397 of 30,383
Broquen
Barcelona, Catalonia
Age
45
I use the ones that came with RHA MA-750I, which are the ones that work best for me. Ordered quite some from AE and Amazon some time ago, but did not work as well.
Was taking a look at it and found that most of double-flange that can be found for sale have some pyramid shape (being the upper flange quite smaller than bottom one), and that was the problem for me (I use M-L size of standard tips and have pretty wide ear canal, e.g. can deep insert ML Spirals).
Actually waiting for some of them ordered few days ago, but they're very cheap and with little or no transportation costs, so I expect them to arrive in 40+ days to Spain.
Be aware with the size of the upper flange as well as the length of the stem considering the physical shape of your ears and nozzle of the IEM you want to try with. The thickness of the silicone (inner stem for sound and flanges for comfort) and the wideness of the bores are important too, but you won't know until you have them, so try to order some different cheap ones if you can.
Reactions: RikudouGoku
post-15191602
Post #26,398 of 30,383
Norway
Norway
Yeah, they're really sweet looking. Please note that that the cable is bought separately for a full $10 :wink:
They're actually really nice, I'd take them over the Hi7 for a more engaging sound. Quite fun and definitely decent buy a good margin. Haven't had too much time with them yet but for your described usage they're more than capable for sure.
post-15191643
Post #26,399 of 30,383
SciOC
Midwest, USA
Midwest, USA
I might have to just switch my Ali order to those rather than the bl03.... They might last me longer than my last lawn mowing pair with an mmcx termination rather than 2-pin! Or maybe I should just get both... And a nicehck db3. Oh how I hate the Ali game....
post-15191657
Post #26,400 of 30,383
Norway
Norway
This is Head-fi, get both lol.
Just kidding but I'm pretty sure these two will be very different sounding. My Blon should be here by the end of this week if I'm lucky so will be able to compare them soon.
Reactions: SciOC
Users Who Are Viewing This Thread (Users: 14, Guests: 13)
