Chinese / Asian Brand IEM Info Thread
- Thread starter Brooko
Nimweth
I'm having a little bit of trouble finding the correct tips for the BLON BL-03. It resembles the Whizzer A15 Pro in shape and like that IEM, falls out of my ears. Does anyone have a recommendation for tips which give a secure fit?
Had the same issue.I'm having a little bit of trouble finding the correct tips for the BLON BL-03. It resembles the Whizzer A15 Pro in shape and like that IEM, falls out of my ears. Does anyone have a recommendation for tips which give a secure fit?
Solved using the largest Starline Tips, they work flawlessly.
Nimweth
Thank you, I'll try that. I had reasonable success regarding fit with some very large foam tips but they did make the sound a little dark.Had the same issue.
I like foams just on 1 or 2 iems.. not more. I do not like the feeling they give in the ears.Thank you, I'll try that. I had reasonable success regarding fit with some very large foam tips but they did make the sound a little dark.
Look what just arrived from Amazon!
BLON BL-03, KZ ZS10 Pro, TRI i4 and TRN 16 core 2 pin cable. I'm going to be busy!
Uh, nice!
I have the TRI I4 and blon on the go for me as well.
I posted a measurement of the Blon BL-03 in another thread.
Try a different cable. The angled MMCX connectors on the stock cable force the IEM into an unnatural angle in my ears. As soon as I switched I get a perfect, comfortable fit.I'm having a little bit of trouble finding the correct tips for the BLON BL-03. It resembles the Whizzer A15 Pro in shape and like that IEM, falls out of my ears. Does anyone have a recommendation for tips which give a secure fit?
1clearhead
- Apr 5, 2013
It's a shame, they would have been nice with that same body style, but with nice rounded edges all around. That would have worked for me.
Nice review.
1clearhead
- Apr 5, 2013
In a situation like this, I usually go a step larger for a more stable and snug fit. For example, on my KZ ED16 and KZ ZSA and its smaller odd shape, I'd hop from medium to large star-line ear tips and it surely gets the job done for me.I'm having a little bit of trouble finding the correct tips for the BLON BL-03. It resembles the Whizzer A15 Pro in shape and like that IEM, falls out of my ears. Does anyone have a recommendation for tips which give a secure fit?
Hope this works for you...
-Clear
Nice review.
yep, I also feel the rounded edges might have helped. as well as longer outputs
Nimweth
Yes, I already changed the cable to one with no ear guides so it's nice and supple and installed large Starlines. It was still slightly insecure so I have now switched left and right earpieces and I'm wearing them cable down. Thank you, though!Try a different cable. The angled MMCX connectors on the stock cable force the IEM into an unnatural angle in my ears. As soon as I switched I get a perfect, comfortable fit.
Nimweth
Thank you. See my reply to Crabdog.In a situation like this, I usually go a step larger for a more stable and snug fit. For example, on my KZ ED16 and KZ ZSA and its smaller odd shape, I'd hop from medium to large star-line ear tips and it surely gets the job done for me.
-Clear
Total: 19 (members: 0, guests: 19)
