loomisjohnson
- Jan 31, 2014
my take on the kz zs10 pro is now on the audioreviews.org blog---the kz machine marches ever forward
the issue with pin polarization only affected to zsn (c-type) versions of jcally cables (which are thought for qdc and bqeyz polarization style, but also work for kz, not out of phase).So technically, straight 2 pin cables should just work fine ootb, right? I'm fine with ear guides/hooks. That means ZS4/ZS5 cable should be fine and AS10/BA10 cable need resoldering. It seems there's no pink cable in ZS4 style pin. Are there any other good alternatives you can recommend for a cable with mic. It'd be really helpful. Thanks
What IEM are you trying to get a cable for?
the rest of 2pins jcally cables use kz polarization; these are straight and have protruding 2pins plug, so perfectly suitable for zs4, but also zs5,as10,ba10.., without removing nor remolding ear guides, nor resoldering plugs.
about mic cables.. there are very few decent models with mic, unfortunately. i haven't got any link of good mic cables ended with protruding 2pins plugs now
KB100 as I'm struggling for comfort with stock cable.
The ear guides can be removed if that’s what’s bothering you about the stock cable. It’s not difficult; you just have to be careful.
I know but I'm clumsy with delicate stuff thus didn't want to take any risks. Will give it a shot. Thanks Slater
It will be similar to this guide I wrote, the main difference being there won’t be a metal wire in the BQEYZ cable.
https://www.audioreviews.org/removing-memory-wire/
Here are the measurements from my review comparing the ZS10 Pro and ZSN Pro. They are almost identical.Mhhh, this is the third time I see someone calling the ZSN Pro and ZS10 Pro similar in sound. Now I'd really love to see some transient response measurements of those two IEMs and I'd be very surprised if the latter pair came out as more clean and coherent.
I've seen this FR graph before on your site, Crabbos (great review as usual!). Now I'd really love to see a nice selection of comparative transient response graphs for good measure.Here are the measurements from my review comparing the ZS10 Pro and ZSN Pro. They are almost identical.
That's another great help for many, Slater; keep it up! Just a note of caution, when I tried to remove the last shreds of the remaining sleeve from my latest KZ cable (the infamous flat, braided, silver plated 8 core version) I accidentally ripped one of the 4 cores of that side. On closer inspection I found some glue residues that I haven't noticed in that part of the connector before, neither on the other side of that cable nor my older one. Just sayin' ...
I have to say, measurements show they're nearly identical in terms of curve.. that being said, i have both as well and the ZS10 Pro is on another league imho.Here are the measurements from my review comparing the ZS10 Pro and ZSN Pro. They are almost identical.
