durwood
So in other words, measurements for:
1. stock (foam and black filter).
2. foam removed, but WITH black filter
3. foam removed AND black filter removed
There has been some discussion recently about FR graphs. I think they can be useful for highlighting such things as channel imbalance, poorly implemented crossovers producing dips and peaks around the crossover frequency and showing up faulty drivers, but their usefulness for indicating sound quality is less certain.
For example you could listen to two CD players and they may sound very different but their FR graphs would most likely be identical: a straight line between DC and 22.05kHz. This got me thinking about the whole replay chain.
From the original microphone, to digital conversion and transfer to CD. This CD may then be inserted into a PC and ripped to mp3 with all its concomitant distortion and compression. This mp3 file will then be transferred to a DAP or phone with its own sound characteristics. Finally a set of IEMs will be plugged in with a FR curve more resembling a mountain range than a straight line. After all this, the fact we can hear anything approaching the original sound is, quite frankly, miraculous!
Jitter/resampling is a time domain issue that doesn't really show in a FR plot. It should show up in Distortion measurements. Then there is a threshold of our human hearing that is able to detect it, but if it is below the threshold of detection who cares? (If a tree falls in the forest and no one is around to hear did it make any noise?) I will give you an example, listening to a track ripped at 48Khz, when the original was 44.1Khz. I had some tracks like this and the cymbals just sounded off (garbled), then I ripped again at 44.1Khz and all was right with the world. Same issue with 96Khz sampling rate, 88.2Khz is a better option if original was 44.1khz because it keeps the timing correct (2x mutliplier), but no new information will be present.
Well, that is where FR is only one piece of the pie, that is the semi easy part but it is known that anything above 10khz or even 8khz is just extra info that we cannot accurately measure. There was a reason Tyll went further with impulse and square wave plots to get s sense of some other characteristics that are masked in a semi simple FR plot.
I like Otto Motor's simple comment, a FR plot will give us a Quantity measurement (or signature flavor), but it does not tell us the Quality. We have to rely on people's subjective reviews and comparisons for more information.
Having said all that, I will provide FR charts of requested MH755 mods but we might not see the changes with the FR plot, here were some mods suggested in the MH1 thread and how it affected the the sound.
https://www.head-fi.org/threads/sony-mh1-r-d-story-and-discussion.634193/page-6#post-8843651
