Chinese / Asian Brand IEM Info Thread
Jan 10, 2019 at 5:05 PM Post #21,226 of 33,689
Just ordered them! ...They were just too cheap to pass up!
This is going to be a three-way fight! Who is going to reign best of the piezo-dynamic drivers!
Artiste DC1 vs **** **** vs Dacom F01!
Stay tuned till next week!
-Clear
Have you tried the Elecom CB1000? That's a contender, too.
Jan 10, 2019 at 5:54 PM Post #21,227 of 33,689
Did you see another piezo toy, the Dacom F01? It's very cheap.
How about this one:
https://www.amazon.com/Tunai-Piano-Audiophile-Earphones-Incredible/dp/B07K8G6YJ1
Jan 11, 2019 at 1:36 AM Post #21,233 of 33,689
Jan 11, 2019 at 5:08 AM Post #21,234 of 33,689
I use my 0.75mm BT20 with my BQEYZ all the time. Works great. I don't have the BQ3, but I have the KB1 and K2.
And it holds securely? I would imagine that earpieces would fall off easily.
Sounds awesome that I would be able to use 1 BT20 for KZs and BQEYZs that caught my interest. Don’t want to end up with 3 version of BT20 in my pockets :D
Jan 11, 2019 at 8:27 AM Post #21,235 of 33,689
Jan 11, 2019 at 8:28 AM Post #21,236 of 33,689
As tight as normal manufacturing tolerances allow.
By that I mean between all of my 0.75mm cables, most fit just right. But there are a few that fit insanely tight and a few that fit ridiculously loose.
The story is the same with 0.78mm stuff.
I used to think 0.78mm vs 0.75mm made a big deal. However, the more IEMs and cables I collected, the more I realized it really doesn’t matter. Whether it’s a bit loose, a bit tight, or perfectly fine seems to all boil down to normal variations in manufacturing tolerances.
The only IEM I have that truly falls off is a QKZ VK1. It’s so loose, no cable fits without it falling right off (both sides). Even the stock cable that came with it. To get a cable to work I had to splay the pins outwards a tiny bit. And that trick works with any 2-pin IEM. That’s why I say it’s no big deal, and I don’t sweat over it anymore.
The other option (when you have a super loose cable) is to tin the cable pins with solder. It adds jusy the right amount of thickness, making even the loosest cables fit tightly.
Jan 11, 2019 at 12:48 PM Post #21,237 of 33,689
I sure will from what I've read very well could have been just as hyped as the DM6 if the DM6 wasn't put into the spotlight first. I'm super excited to get them how long did it take for yours to come?
I got the default template version from Penon which was in stock. Came in a week. Your custom order will take time as it is built on order. What ETA did Penon give you?
Jan 11, 2019 at 12:56 PM Post #21,238 of 33,689
It didn't give me a ETA but that's probably due to it being a custom order I'm guessing about a month. I'm not really worried about it taking forever penon has great service and they were very accommodating when I was trying to decide what color I wanted they even sent me some real life pictures of the red color I wanted.
Jan 11, 2019 at 4:45 PM Post #21,239 of 33,689
While it's too early to give listening impressions, here are measurements of the Tenhz T5, taken using a Dayton iMM-6 microphone using a vinyl tubing coupler. Measurements are calibrated but uncompensated, using 1/12th smoothing.
Jan 11, 2019 at 6:35 PM Post #21,240 of 33,689
Do you have the P4 pro and if so how is the bass compared to it because it looks like it has a touch more.
