kahaluu
agreed but one member experience turned from bad to good so let continue burning in
Well, it's your call. I don't think you'll hear a dramatic difference though.
Comply T200, nozzle too big or too small?I received my XE800 last week. Have been burning them in for almost 48hrs and then took a listen. At first I thought wth how could they sound so thin, then I found out I wasn't getting a good seal with the stock tips so I changed to the large stock ones. Still no seal! Had to rummage around in my IEM drawer, finally found a suitably large enough tip from an old Sony IEM I have and that's what I've been using. I've tried the other tips I have (Comply T200, KZ tips, Xiaomi tips) and all of them either didn't give me a good seal or weren't able to fit onto the nozzle.
The XE800 sound fine, but maybe a bit too bright/bass lean for me even with a good seal. Nozzles that can rotate seem to be quite awkward. Cable is very thin and fragile looking and feeling.
Anyone else having this much trouble with tips for the XE800? What other 3rd party tips are you guys using with them?
Seems like the best value IEMs at $15? Gotta sell more of my earphones before I buy new ones.
if anyone cares, i posted a review of the urbanfun here: http://www.head-fi.org/products/gemtune-urbanfun-hifi-dual-driver-in-ear-headphones-hybrid-balanced-armature-dynamic-earbuds/reviews/17147
Do you happen to have (heard) the xe800 and/out havi b3?
i use stock large tips, filled with foam (kind of sony hybrids). but tried new kz's dark gray yesterday (large size, no foam filled) and sealed perfectly as well. you'll get better bass.
The cable is not as weak as you (and what I previously) thought.
