GrassFed
So... Audimi Y02 aka TRN V20, I have two things to say about it. First, it is such a pain to get proper seal. The ribbed front edge is also just dumb - the shell of these in-ears should be completely smooth. And second, once seal achieved, its sound quality is boss level. The sound stage is the biggest I've experienced so far, with great separation. The music just pulls you in. One thing though - the BA treble is a tiny bit overcooked for me, I had to turn it down a couple notches using Neutralizer EQ app. But it might just be perfect for you if you're not sensitive to or prefer strong treble. For me, it needs to be softened somewhat for better coherence.
The problem with seal is probably because the nozzles are angled very forward and not inward enough to the ear canals. But the Chi-Fi gods (each of them has many unpronounceable names) finally took pity on me and allowed for one pair of tips that worked wonder - the biggest, softest silicone tips that came with the IBasso IT01. The ones I've never successfully used on anything else, including the IT01. They're narrow bore btw.
The bright side of this tip rolling struggle is that I found wearing IEMs so that nozzles pointing more forward seems to open up the soundstage. All the ones that give spacious sound that I like appear to fit this mold - BS10, Omars A3, Morpilot dual dynamic. Might or might not work for you - just want to share
