groucho69
Not much! Taking apart isn’t always the problem either - it’s putting back together again that can be the challenge lol
Especially when there are 3 parts left over.......
the sound will be more openEspecially when there are 3 parts left over.......
Id personally stay away from the F9's. I had the f9 pros they were simply unlistenable. The treble was painfully sharp, no bass and just a really uncomfortable sound if you listen at any sort of volume. And this is from someone who likes a bright trebble and a good old v signature. Beautifully made casings and cables, but shocking sound.Hello everyone, a question I want to buy my earphones in ear for a value of 100 dollars but I do not know what to buy. Currently from what I could see of the best reviews are Fiio F9 and Shure SE215, what would be better or what other recommendation could you give me? I am looking for the cable to be removable as much as possible so they will last as long as possible.
Hi, thanks for your response. In the end I was not convinced by the Fiio F9 or the F9 PRO because I saw them very expensive compared to the headphones mentioned here.Id personally stay away from the F9's. I had the f9 pros they were simply unlistenable. The treble was painfully sharp, no bass and just a really uncomfortable sound if you listen at any sort of volume. And this is from someone who likes a bright trebble and a good old v signature. Beautifully made casings and cables, but shocking sound.
The trn v80s are infinitely better in my opinion in terms of sound.
Oh man, do not tell me this I'm already regretting it and they still have not arrived.Just had the KZ ZS6s arrive today as they were about £10 in the AliExpress sale so I thought it would be rude not to give them a try.
Well all the reviews about the treble definitely are not wrong! These are so top end heavy that there is next to no mids and a serious lack of bass. It sounds like theyve shoved all the drivers in with no crossover at all and they all just fire away full belt.
Will have to try the foam in the 'oles trick and see what difference it makes, but I think these will just be kept because they look cool. As I doubt the foam will make them much better but worth a try.
Really nice looking and solid casing though, but terrible fit for me.
But on the plus side they've saved me a small fortune from ever buying any Campfires that have this case design as they are just really uncomfortable and dont fit my ear shape at all.
I did also pick up one of the upgraded KZ silver cables with the machine ended 2 pin connectors. Really nice cable if anyone is looking for a dirt cheap upgrade.
Don't just rely on one person's view. Every one has different sense of hearing. I also have KZ ZS6 and I like it very much. I don't hear the heavy top end and serious lack of bass as described by crezo. By the way, I'm a classical musician with very good hearing.Oh man, do not tell me this I'm already regretting it and they still have not arrived.
What if a tip I read from many, the pads of the brand itself are garbage, do not fit perfectly and then fall or rather you stay in the ears.
You never know you might like them. But personally they are really not for me. Fit and sound I just really didnt like, but then everyone has different earsOh man, do not tell me this I'm already regretting it and they still have not arrived.
