mbwilson111
- Oct 13, 2016
Same here. I love mine, and it's beautiful to look at!
ok that just tipped me over the edge...last one on Amazon UK prime
I've got the 2016 version of the Magaosi BK50, and it really sounds good, and has the inline Mic / Audio Controls.
The new version is available with a connected cable, or with MMCX connectors, so you can use a cable of your choice.
https://www.aliexpress.com/item/Chr...dphone-Driver-BA-HIFI-In-Ear/32783911942.html
I just popped in quickly out of curiosity. And I realize that I must get out just as quickly!!!
Seriously, thankfully I don't do iem's anymore. Otherwise you guys & gals would be sucking me into buying more than just earbuds and headphones lol
Stay... we have iems.
I think you meant "we have buds". If so, then okay - I'll stay!
Then you must try the MEMT T5. It is a gem among ear buds and very solid and sounds like you're actually wearing hi-end IEM's! For me, personally the best ear buds I've heard so far.I think you meant "we have buds". If so, then okay - I'll stay!
But iem's are a no go for me: they make my ears itchy and prone to infections, and they flare up my tinnitus (which has disappeared since stopping with iems).
Link...
https://www.aliexpress.com/item/Original-MEMT-T5-In-Ear-Earphone-3-5MM-Stereo-In-Ear-Headset-Dynamic-Earbuds-Hifi-Bass/32855938707.html
Btw, when copying an aliexpress link, I usually delete all of the stuff after ".html" since it's useless and just takes up space.
good point... I try to as well. What does all that do anyway? Does it give hits to advertisers?
btw... certain sellers are not to be mentioned or linked to ... check Slater's signature. This and another thread keeps getting in trouble..
I think so.
How the heck are users - especially newer ones - supposed to know that those sellers and brands are banned? I've been discussing the PT15's all over the place (as have others), and I didn't have an inkling that the brand was banned.
I refer to them as "closed ear buds"I definitely will give mine a good listen this weekend. I got them out last night and then got sidetracked with something else.
After @crabdog said the MEMT X6 was awful, I just had to listen to mine. Happily listened to three albums that I know well and did not find anything to be awful.
I like the magnetic feature on the MEMTs.
I call my T5 a pod... it is not really a bud? or is a pod a bud? Very very comfortable... more so than most buds or iems for me.
I wish they would just decide that this punishment for past deeds has gone on long enough.
The fantastic SENZER H1 is back on Aliexpress for 9€. That's my recomendation. IMO you can't beat that price for detailed sound with fantastic bass. It reacts very well when amped, producing a balanced sound. Wide soundstage too. It's not the latest IEM on the road, it's not hyped, but what a gem it is!
I have never seen a nozzle screen that was stuck on tightly. Usually they are barely adhered with a reusable adhesive. And there's a few that are attached with a tiny bit of non-reusable glue (KZ ZST, Meizu EP52, etc).
So if it's stuck so tightly you can't even remove it, my guess is it's gooped on with a ridiculously excessive amount of glue (like the V60 shown earlier).
