Slater
Allright! So I will have to either punctuate or remove the filter? Will try the first first.
I’d like some help with the filter removal, never modded before apart from putting a sticker on the Tin Audio T2 bass vent.
Well, you use a very fine (and sharp) sewing needle for both methods.
If you don't have any sewing needles, you can buy a whole pack of them at many stores for about $1 (walmart, any fabric store, any craft store like Michaels, possibly a Dollar store, etc). They are extremely useful to have anyways, and it is easily the 1 tool I use more than anything when working on and modding IEMs.
- For the "poke holes" method, you use your needle to poke the individual holes of the nozzle screen. Then you move the needle around in a circular motion, so your fingers and the needle make the motion in the shape of the cone of a funnel (if that makes sense). You will see the hole open up larger. Then you simply move onto the next hole and so on, until all of the holes are opened up like IEM in the left side of the photo I posted above.
- For the removal of the nozzle screen, you would use the needle and stick it under the edge of the screen, then GENTLY lift it up. If you have ever opened a paint can before, it is the same idea: https://thediyplaybook.com/2014/06/how-to-openclose-paint-can-without-mess.html
