CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
- Thread starter NymPHONOmaniac
realkandar
- Feb 6, 2012
Hai all
I'm very happy has a best budget thread for iem.
I need some help for get perfect in ear monitor under $100 and under $50.
I like to diy audio cable, and i need perfect iem to help me analyst cable. That's why i need detchable iem.
And of course i'm always listening music.
My genre is trance, alternative and jazz.
After i sreach much iem, i love tin audio t2.
About t2 review is only some people, can't find a lot of review about t2.
I want to asking about t2 with wo has using them.
I want to know about accuracy, ability, natural, staging and haow about bass and mid bass. I'm not bass lover but need depth bass and tight.
Or just almost nearest on T2?
I have some candidate....
But i need t2, so must got truly review about them.
I hope somebody can help me to give me review or another suggest.
dhruvmeena96
Well bro, T2 is have dual driver... One is carbon driver 10mm and one is Knowles SR dynamic armature driver 6.2mm to be exact.
It has a hole in front to relieve people from pneumatic pressure inside ear
And a hole at back to make sub bass possible.
Signature is very much to neutral.
Bass is very fast, punchy and have leveled decay...... So it may not have enough bass for some people but I am coming from u18tzar so it is cool and fast bass which give itself a definition and texture...and have a property of not sounding like fart like BA driver(when they do bass).
Treble is very clean under 50$....I must say controlled good.
Mids are fantastic and revealing
realkandar
- Feb 6, 2012
Thanks you dhruvmeena96.
I hope your review will helpfully.
So it means it's almost perfect with low budget. If compare with M6 pro how about it?
I have plan take M6pro and T2.
But if T2 and m6 pro is not far from quality.
I will take t2 only. And change the m6 pro with kz. But for now i still need more solution between zs5/zs6/zsr/es3.
Thank you bro...
dhruvmeena96
Bro m6 pro isolate better
But tin audio t2 resolute better.
I think less pneumatic pressure relieves your ear well making sound bigger.
They have same signature....t2 does better due to low distortion on dual driver setup.
Well I would say 30% better handling of sound than m6, sounds quicker and bigger but doesn't isolate as well as m6 and there can be a chance of coherency issues on very very very fast songs(well no song is that fast till date to do that.....I mean that fast) plus m6 distorts on DSD rap god by Eminem super rap on my agdr cmoy dual opamp edition amplifier. Tin audio T2 scales well.
Sound is about 30% better on same signature.
Easy man language.
Goes deeper in bass but in very controlled fashion....tighter than m6.
Mids are somehow nearly same in both.
T2 have airy and smoother treble than m6. Something remininding me something between etymotic er4sr and u18tzar treble, but with some peaks and dips and some slight loose one....dynamic driver treble....can't help it.
I am using agdr cmoy dual opa1688 amplifier....the one of the most neutral amps....and Lenovo z2 with its internal Sound circuitry enabled
Easy man language.
dhruvmeena96
Less pneumatic pressure leads to less driver flex and less pressure to your ear drums on the loss of isolation and is healthy for ear drums.
Pneumatic pressure can lead to something like what happens when you cold and your nose is dripping and when you suck air from nose by pressure your ears get blocked..
Well that is extreme case, but earphones tends to do this to ear diaphgram...
T2 doesn't and that is why it sounds better.
I once did block the vent in front which increased bass, but after sometime a reverted because it made my ear diaphgram getting inside killing mids and treble response and making a 7khz peak sibilance
dhruvmeena96
Well this may help everyone on thread.....some of my observation
dhruvmeena96
Well I want to ask about yersen fe2000.....how good are they compared to tin audio t2
realkandar
- Feb 6, 2012
Easy man language.
Perfect...
So i'm not wrong make t2 as my candidate and now i fix to get tin audio t2.
Thanks bro dhruvmeena96 for your review and sharing.
So i will back with my T2 in this thread.
Maybe i'm so selective about in ear. Because i use that for my experiment too.
From what is match with me, it's make me easy to analize cable that good or not.
realkandar
- Feb 6, 2012
I never try yersen, but maybe someone can help you for this iem.Well I want to ask about yersen fe2000.....how good are they compared to tin audio t2
dhruvmeena96
Well....bro its like, cables won't make that huge difference.....
Well.....what I am believer of is to make the cable yourself...
Make a 16 braid cable
Well make 4 wire round braid and then take 4 braided set and make a flat braid...
Well this is hard...check diy cables
4 wire in parallel will drop the resistivity by fraction of 4 but then it is +/- so double length..
Means overall fraction of 2.....or half the single wire.
Use 7n silver and then throw in some cyro unit.
They charge at most 10$ as they throw it with their own other products.
I got it for 3$
Ask for slow cyro
Get connectors
Your 50$ super cable ready.
This cable is sold for 1000$ by cable makers
Well they have higher QC etc.
The super expensive cables like one I don't remember
Used silver peptide which was actually a scientific alloy for better atomic flow of current.
Well it was 5000$
But only that cable made a difference to my ears.
Other cable had the psychological effect of draining cash and flaunting it.
And when you diy the cable yourself.....you will feel very very proud of your work and that would be some real satisfaction......
I got it for 3$
Ask for slow cyro
Get connectors
Well it was 5000$
I just got the Yersen Fen-2000 and it is a very good iem, got more bass than the TinAudio T2, very comfortable. Great for what it costs, I'm still working on the right tip for me
realkandar
- Feb 6, 2012
Yes... Most people got psychological effect.Well....bro its like, cables won't make that huge difference.....
I got it for 3$
Ask for slow cyro
Get connectors
Well it was 5000$
Cable maybe not much make different.
I know has some expensive cable is good, but.... All of cable is not talking about metalurgy. But about current and perfect extension. Solder and tin. Diameter and many. Geometri.
From all of this is how can make super thin and flexible cable for iem.
Maybe after got my iem. I will much sharing with you about cable. N i need your idea.
But.... Once again, thank you bro for your sharing. It's very helpfull for me.
dhruvmeena96
@realkandar well I worked with sonion and zsounds in past.....so I know whats there in audio tech...
I am a computer engineer by the way....working with nvidia.
But I know all about tuning and making balanced armature...
So.......hahahahha
So.......hahahahha
realkandar
- Feb 6, 2012
Really....@realkandar well I worked with sonion and zsounds in past.....so I know whats there in audio tech...
So.......hahahahha
So maybe i can get your opinion and your suggest for audio cable.
Please give me your advice. Maybe later i will DM you.
Total: 17 (members: 0, guests: 17)
