riffrafff
you guys are a bad influence ,my z5000 and nicehck bro are on the way,and im thinking of getting the yersen.....
Abandon all hope, ye who enter here. (Oh, and abandon thy wallet, too!) LOL.
Hmmmmm....rather similar to the EDR2 and not any worse. I prefer them over the ED3.Did EDR1 are similar sounding to ED3 perfection?
Thats a shame really. You should write your story to the seller and ask for refund ASAP.
Now, i'm little less intrigued by these cause of serious QC issue....but you look so impress by sound, even with this torturous defects....well well.
I own in the past Auglamour AG-R8 and wasn't impress at all by the sound....but these look something different from another league.
Went ahead and ordered the Yersen FEN-2000 because I'm a sucker for braided MMCX cables without memory wire. I'll post impressions once I get it.
I also saw these in the related items from the same store, which looked interesting. Hi-Res certification, nice-looking (albeit non-detachable) cable, metal construction.
Hehe, now, talking so much about EDR1 and 2...I guess I will order one!
My QC issues with Auglamour RT-1 continued today. After fixing one side where DD popped out of place, it started to completely cut of from time to time and after opening them again, the circuit board on the back of the driver was not glued enough and was almost separated from driver. Tried to glue it back, cutting off remained and my tinkering with it resulted in broken coil wires. Even then I didn't give up hope because I knew I could fix it back if I could isolate these small wires from the black goo that holds them from the back board to the membrane. Unfortunately, I only managed to save one of them while the other one was cut = useless driver.
Then I opened the working side because I was thinking about buying a new pair of 10mm drivers to put inside. First thing: confirmation that I was definitely right about polarity - one of my sides had wrong internal wiring resulting in polarity issues (I knew about this and was just careful to connect one side with cables inverted). The most bizarre thing is that they inverted wires on one cable for the bluetooth module - they knew that they f-ed up wiring and instead of rewiring inside the IEM they just ordered one cable to be wired in wrong polarity essentially "fixing" the issue with this pair - too bad that they didn't think of the people who might not know enough about audio and who might end up thinking that 3rd party cables suck. This is also a very bad business practice that I did not expect.
And one more point of frustration - Balanced Armatures do not perform the same on both sides and after closer inspection, the properly working BA is a full range driver (I also suspected this given the size of the driver which is too big to be a tweeter).
The weirdest thing is that even with ridiculously messed up pair of RT-1 that I received, it sounded sublime. I don't know exactly if this is an isolated case but I sure hope that it is because I believe in Auglamour and still have high hopes for them. Their RX-1 is a very good example of a spectacular product and RT-1 probably is as well (for most people I think).
Audiobudget dude like them but especially for built, sound look strange and even 5 stars IEM he suggest aren't always WOW creature so I consider Igor kinda not enough severe and only try his 5 stars or excellent (and hysterical) sound rating.Went ahead and ordered the Yersen FEN-2000 because I'm a sucker for braided MMCX cables without memory wire. I'll post impressions once I get it.
https://thecontraptionist.blog/2016...-place-to-begin-your-audiophile-journey-pt-2/
Can you explain (again perhaps) the difference it do? I have micropore tape and will test it for sure cause something just don't work between me and T2.....In contrast to my current experience with RT-1, T2 has been nothing but glorious. I taped front vents with micropore tape and punctured a small hole in the tape which brought bass and sub to a better level. Just micropore has a negative effect on a lot of aspects, I can only imagine what clear tape or blu tack does. AudioBudget lost all credibility with me after this, going for insane bass while trumping the rest of the sound is never the way in my book.
On the subject of Equalizers, I got a Xiaomi Mi5 Smartphone and it has some presets for "mi sound enhancement" or something like that. Presets for their piston, headphones, hybrids etc. Any opinions on if this is worth using at all?
I also use Poweramp as my music player app, they also got a EQ which you can play with and some presets for specific genres.
Most people here seem to dislike EQ, and just want headphones IEM, that sound good ootb, but is using EQ really that bad to counter specific weaknesses?
I see Audiobudget as a chifi explorer and kind of the ultimate guinea pigs, to take always with a grain of salt....like most reviewer I guess. His 5 stars rated iem always worth more investigation, but this guy search for real, he's not find by a PIMP like some others....I think its passion about chifi is sincere. But interested too as 99.9% of human being that give effort for something.
