Smiped
- May 25, 2015
What cable should I buy for the **** PT15? I want a MMCX connector that can withstand a lot of strain aside from the stock one that arrives with the earbuds.
No cable is indestructible, especially MMCX which are all fragile in my experience.
Are you generally really hard on cables, or are you using them for rugged sports, like sky diving or parcours?
What's your cable budget? I've seen them range from $15 to $200+.
Yeah I know there is no such thing as indestructible cables. In fact there are very few things in this world that is "indestructible" in its strictest sense. But I do want a cable that can withstand daily usage commuting from work or to school. I would just like a cable that is durable when I listen to music while I ride the bus.
I'm not too hard on it, but sometimes I do throw them around or sometimes they might get caught on a doorknob here and there. This doesn't happen always though, maybe once or twice. I don't do activities that are rugged. I just need a cable that can go through everyday situations. I don't want to spend too much on cables cause I don't want the cables to cost more than my earphones lol. So my max budget would be like $15 to $20, but generally the cheaper the better if the quality is more than suitable for the conditions that I go through (which isn't much to be honest.)
A number of people have this new KZ MMCX cable, and the reports are very positive. I have multiples of the 2-pin version, and it's a well made, good sounding cable.
https://www.aliexpress.com/item/New...le-Use-For-Shure-SE535-SE846/32820576571.html
The price is low enough that you can afford to replace them if they break within a year. If it was me, that's what would be near the top of my list.
If I remember correctly, dear HungryPanda really like them and he got LOT of IEM, he say they are V shaped and quite clear sounding....but dear Panda is a man of few words too hehe so, PM him perhaps (sory Panda!)Does anyone have an in depth review of the Svara Reds? Or a brief sound signature for it at least?
Do you have balanced gear? If so, perhaps one cable of both would be interesting as I find the PT15 to Shine even more when balanced! but they sound good without it too. Can I know what's you audio source?Okay, thanks. Just wondering is that cable you linked me compatible with the **** PT15? Cause if so I am just going to buy the earbuds alone without the standard cord and buy 2 of the cables you've linked.
Im always a fan for QCY IEM earphones. However despite trying many other models from QCY, i still find QCY QY8 is the best as it produce nice clear vocals while good deep bass. Is it me or you think other QCY earphones could have matched up or even better than QY8?
