Tripowin’s Lea arrived. Hey! The cable is pretty! I was expecting GK10 class cheap one, but great job tripowin.
Note: the L/R 2 pin indicator did not tell which one is the front, so I tested both ways:
-the letter of R and L facing outside of the IEM: off phase, imaging center will be into-your-head, and get blurred
-the letter of R and L facing inside (toward your head): sounds correct, imaging moved forward, and positioning sounds properly done
OOTB, a few seconds of first intro of Mussorgsky, great gate of Kiev, “hmm not bad! As a $19 IEM this is a gamer changer! But not as detailed as Aria, both similar tuning.”
By second song Hiromi’s Warrior, the acoustic jazz session, when floor tom start to rumble:
“Yes, now I can confirm. This is a proper LCP, bass transient is smooth and natural”
Vs Tripowin Mele $50-60? I forgot.:
Forget about Mele, Lea is better in every aspect with $19. It’s a straight upgrade to me.
Vs Aria OG(metal filter removed):
Aria is a better player but it cost 3x more, with more airy wider sound stage. But that is hard to push 3x price tag, as an entry to the rabbit hole, if we are talking about IEM itself.
Packaging meanwhile, Tripowin Lea is a minimalist: “you only need IEM, nothing else”, Aria consider box openening as a part of leisurely experience, so Moondrop is a better player here, Aria’s packaging (unless someone is not anime/waifu phobia) is a very pleasant and is at stage of high-end.
For moondrop’s packaging, I’d find Starfield’s one as one of the best one over all IEMs package I had before. Good balance or waifu / art. Outer cover is a waifu silhouette with beautiful (Shinkai Makoto style) star field, which goes all the way to the back. Then the actual packaging container is a minimalistic yet high-end feeling and touching paper. This particular package is a good gift to girl to my impression.
Anyway! Lea is good counteroffer from Linsoul, to A-Ria.
And I totally forgot Chu! It’s hard to pull whether Chu or Lea is better, Chu’s note is thinner, Lea is thicker. But Chu’s cable is not swappable, while Lea left a choice for users. I’d pick Lea over Chu for rock/billboard hit chats, and Chu for J-pop/classical over Lea.
