Barndoor
He already has that one in his signature!KZ DQ6!!
Might help if you tells us what you don't like about your current iems.
+1KZ DQ6!!
I have sigs disabled and didn't see thatHe already has that one in his signature!
KBear KS1Is there a set for ~30-40$ with the following features:
-great for EDM
-lively and fun engaging sounding
-good bass (but bot basshead, I already have such)
-great mids for vocals
-for a treble sensitive person - these s, sh, and other shouty sibilant stuff are bullets to my brain....
-over-ear, no MMCX
(optional great soundstage)
Still searching for such IEM to say "wow" and stop buying
No, they just need a good DAC to play high quality music and probably to amp the IEMs a bit more.Maybe the iPhone as a source is the issue rather than the iem (I don't own an iphone)?
Already have them, did not spend many time as I wait for a new cable but I think they have some treble peaks I will not love.....KZ DQ6!!
The DQ6 is pretty good but you'll likely have to replace the tips. The CCA CSN is a similar IEM but they should have a more polite tuning from what I've read. It's cheaper too, but the tips they come with also suck.I guess this is the better thread to ask this question instead of the KZ thread.
I'm in the marked for my first proper IEM's. My current "setup": ATH-M50X, Xiaomi HD Pro. I mostly listen through Spotify and my phone.
I have a very broad taste: Rock, EDM, Classical. I like the sound of the M50X, I think my Hd pro's sound a bit muddy. I remember the first time I listened to my M50x's, and was happily surprised. I know they're not the best, but at the time they started my appreciation for good sound.
I first started on the ZS10 Pro, but after reading some more I landed on wanting the KZ ZSX cause that seems to be an improvement on that. And after that started reading more and more. In other words: I dropped in the IEM hole. Really interesting! Can be a bit overwhelming, which is why I decided to go with KZ for now.
For now I'd like a pair that compliments or at least is on the same quality level as my M50X. I'm not sure what my favourite sound is yet. I need an IEM that can handle most of those genres and can work as my "workhorse" that I always take with me. And that might have some room left for me to learn from and appreciate.
Recently I see the DQ6 a lot too. Especially in this thread. And I guess it's because it's newer.
So my question: DQ6 or ZSX? I'm not planning on buying multiple IEMs yet and don't want to spend more than the ZSX. Price difference is around €12 between the two.
Or maybe something totally different? I've seen TD08 come back in a list too. Or still the zs10pro because it's a bit cheaper?
Thanks! I have some tips from previous in-ears, and the seller I'll be buying them from includes foam tips. So that won't be a problem as long as I buy from him. Lucklz or something.The DQ6 is pretty good but you'll likely have to replace the tips. The CCA CSN is a similar IEM but they should have a more polite tuning from what I've read. It's cheaper too, but the tips they come with also suck.
With all my IEM's I only use the stock tips for just a short time to check them. Then I usually use Spiral Dots unless there are fit issues. Over the years I have collected Spiral Dots, Azla Sedna Earfits, and various other tips that can really change the sound of an IEM from torture to pleasure. Of course all people are different so it's good to get a collection of eartips that suit you so that you can get the peak performance for your ears.Already have them, did not spend many time as I wait for a new cable but I think they have some treble peaks I will not love.....
@cappuchino I'm waiting also tips, so that's why I avoid listening to them aside 10min when unboxing to check if they works...
The answer: CCA CSNIs there a set for ~30-40$ with the following features:
-great for EDM
-over-ear, no MMCX
The CSN has a lower and rich sub-bass response due to the larger chamber. The midrange is not at all forward and peaky, but it's actually very clear plus smoother. Finally, the treble sounds technically different and controlled because of the excellent tuning CCA did to accomplished this feat. Overall, it's technically better and warmer than the DQ6, while DQ6 is just brighter and peaky towards the upper midrange.CCA CSN is quite similar to DQ6; I do not want to be redundant...
